Maybe this is glaringly obvious, but I've searched the forums and looked at the documentation and can't find anything that describes how it is possible to individually align columns. I know flowdirection will make a grid align one way or the other, but I'd like to have one column aligned left and one aligned right. Is there any way to accomplish this?
EDIT: Okay, I've found that you can set the FlowDirection of the DataRecordCellArea, but is it possible to set that in the codebehind? If not, where would I need to put it in an itemspaneltemplate that has a grid?
Thanks,Matt
Ok I figured this one out on my own. I added a style for the cellvaluepresenter and it works like a charm
<Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="TopAlignField"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}"> <igEditors:XamTextEditor Margin="{TemplateBinding Padding}" Width="{TemplateBinding Width}" Height="{TemplateBinding Height}" VerticalScrollBarVisibility="Disabled" Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content}" Background="Transparent" BorderThickness="0" BorderBrush="Transparent" HorizontalAlignment="Stretch" IsEnabled="False" VerticalAlignment="Top"/> </ControlTemplate> </Setter.Value> </Setter> </Style>
set the fields cellvaluepresenter style to it and it works
<igDP:Field Name="LogID" Column="0" Label="Log ID"> <igDP:Field.Settings> <igDP:FieldSettings CellValuePresenterStyle="{StaticResource TopAlignField}" AllowEdit="False" CellWidth="60" LabelMaxWidth="60" CellMaxWidth="60" /> </igDP:Field.Settings> </igDP:Field>
Is there any way to set the vertical alingment for the text@
I have a grid with several cells that wrap and the "unwrapped" cells have the text vertically aligned in the center of the cell by default
I need them to be "top" aligned.
anyway to to this?
Hi Philipp,
You should be able to do what you need by supplying a style for LabelPresenter. However, there is easier way. There is a property exposed off FieldSettings called CellContentAlignment. This property was exposed mainly for use in situations where the labels are with the cells, i.e. not in a separate header. It controls the placement of the cell relative to the label. However, even in the default case where there is a separate header it should affect the horizontal alignment of the label. Try setting it to something like 'LabelAboveCellAlignRight'.
I hope this helps.
Hi Joe
What about horizontal alignment in the column headers? I've opened a support request a long time ago, but support couldn't help me as it appeared this got somewhat lost (the possible overrides screwed up themes). Is this supported with 7.2?
Cheers,
Philipp
Hi Matt,
One way to do it is to specify the HorizontalAlignment for the editor used in the cell, e.g.
<igDP:FieldLayout>
<igDP:FieldLayout.Fields>
<igDP:Field Name="Phone number">
<igDP:FieldSettings EditorType="{x:Type igEditors:XamMaskedEditor}">
<igDP:FieldSettings.EditorStyle>
<Style TargetType="igEditors:XamMaskedEditor">
<Setter Property="HorizontalAlignment" Value="Center"/>
<Setter Property="Mask" Value="(###)###-####"/>
</Style>
</igDP:FieldSettings.EditorStyle>
</igDP:FieldSettings>
</igDP:Field>
</igDP:FieldLayout>
</igDP:XamDataPresenter.FieldLayouts>
