I have a TabGroupPane within a XamDockManager. If I undock the tabs so that they are floating ContentPane objects and overlapping each other, how do I programmatically change the Z-order of one of the ContentPane objects underneath another to bring it to the front? ContentPane.BringIntoView() doesn't work unless it's docked on the TabGroupPane.
Jason
Brilliant, that worked perfectly!
When the panes are floating they are hosted in WPF Windows. I'm not sure we should (and I know the WPF window doesn't) interpret a cal to BringIntoView as a means to change the z-Order of the windows since BringIntoView doesn't change the z-order of elements in a panel either. In any case, if the pane is floating you can get its containing ToolWindow and call BringToFront on that. e.g.
