690
SaveLayout() and LoadLayout(() do not work for a floating ContentPane
I wrote an application that uses one XamDockManager with a bunch of panes.  I also used the great LoadLayout(() and SaveLayout() methods.
Everything works, except this scenario:
1) A user floats one of the ContentPanes and ends the application.  I call SaveLayout() before ending the application.
2) When the user starts the application again, I call LoadLayout(), but the ContentPane that was floated on the previous run only appears for a couple of seconds and then disappears (while it's visible, it's at the correct position)
Is this a bug?  If it's not, what am I doing wrong?
I copy below the original XAML, the saved XML and the relevant code-behind - in my example below, the "Action Items" ContentPane ("dcpActionItems") is the one that floats and becomes invisible after I call SaveLayout()  and then LoadLayout(().
Original window.xaml (before layout changes)
 <igDock:XamDockManager HorizontalAlignment="Stretch" Margin="0,0,0,0"
                        VerticalAlignment="Stretch" x:Name="xdmDockManager" Theme="Generic">
    <igDock:XamDockManager.Resources>
      <ResourceDictionary>
        [... XAML deleted for simplicity ...]
      </ResourceDictionary>
    </igDock:XamDockManager.Resources>
    <igDock:XamDockManager.Panes>
        <igDock:SplitPane x:Name="dspNOTRELEVANT1"  igDock:XamDockManager.InitialLocation="DockedRight">
            <igDock:ContentPane x:Name="dcpNOTRELEVANT1"
                Header="NOTRELEVANT1"
                AllowClose="False"
                AllowFloatingOnly="True"
                AllowDocking="True"
                AllowDrop="False"
                AllowPinning="True" >
                <Grid>
                </Grid>
            </igDock:ContentPane>
        </igDock:SplitPane>
    </igDock:XamDockManager.Panes>
    <igDock:DocumentContentHost>
        <igDock:SplitPane x:Name="dspNOTRELEVANT3" SplitterOrientation="Horizontal">
            <igDock:TabGroupPane x:Name="dtgpActionItems">
                <igDock:ContentPane x:Name="dcpActionItems"
                    Header="Action Items"
                    AllowClose="False"
                    AllowDocking="True"
                    AllowDrop="False"
                    <Grid>
                    </Grid>
            </igDock:TabGroupPane>
            <igDock:TabGroupPane x:Name="dtgpNOTRELEVANT2">
              <igDock:ContentPane x:Name="dcpNOTRELEVANT2"
                Header="NOTRELEVANT2"
                          AllowClose="False"
                          AllowDocking="True"
                          AllowDrop="False"
                          AllowPinning="True">
                <Grid>
                </Grid>
        </igDock:SplitPane>
    </igDock:DocumentContentHost>
 </igDock:XamDockManager>
Code behind
  Sub LoadLayout()
    Dim fs As New FileStream(cLAYOUTSETTINGSFILENAME, FileMode.Open, FileAccess.Read)
    Me.xdmDockManager.LoadLayout(fs)
  End Sub
  Sub SaveLayout()
    Dim fs As New FileStream(cLAYOUTSETTINGSFILENAME, FileMode.Create, FileAccess.Write)
    Me.xdmDockManager.SaveLayout(fs)
  End Sub
Layout Settings XML ("Action Items" not floating - same as original XAML above)
<?xml version="1.0" encoding="utf-8"?>
<xamDockManager version="9.1.20091.1006">
  <contentPanes>
    <contentPane name="dcpNOTRELEVANT1" location="Document" />
    <contentPane name="dcpActionItems" location="Document" />
    <contentPane name="dcpNOTRELEVANT2" location="DockedRight" />
  </contentPanes>
  <panes>
    <splitPane name="dspNOTRELEVANT2" splitterOrientation="Vertical" location="DockedRight" extent="367.76">
      <contentPane name="dcpNOTRELEVANT2" />
    </splitPane>
  </panes>
  <documents splitterOrientation="Vertical">
    <splitPane name="dspNOTRELEVANT3" splitterOrientation="Horizontal">
      <tabGroup name="dtgpActionItems" selectedIndex="0" relativeSize="100,108.247022902351">
        <contentPane name="dcpActionItems" />
      </tabGroup>
      <tabGroup name="dtgpNOTRELEVANT1" selectedIndex="0" relativeSize="100,91.7529770976487">
        <contentPane name="dcpNOTRELEVANT1" />
      </tabGroup>
    </splitPane>
  </documents>
</xamDockManager>
Layout Settings XML ("Action Items" floating - LoadLayout(() does not work)
  <contentPanes>
    <contentPane name="dcpNOTRELEVANT1" location="Document" lastActivatedTime="2009-04-22T00:47:16.8288078Z" />
    <contentPane name="dcpActionItems" location="Floating" lastFloatingSize="622,189" lastFloatingWindowRect="72,265,638,223" lastFloatingLocation="72,265" lastActivatedTime="2009-04-22T00:47:08.419967Z" />
    <contentPane name="dcpNOTRELEVANT2" location="DockedRight" lastActivatedTime="2009-04-22T00:41:43.0194302Z" />
  </contentPanes>
  <panes>
    </splitPane>
    <splitPane name="Z92282895671f4e8a934a31cfb2439509" splitterOrientation="Vertical" location="Floating" floatingLocation="72,265" floatingSize="622,189">
    </splitPane>
  </panes>
      <tabGroup name="dtgpActionItems" selectedIndex="-1" relativeSize="100,108.247022902351" />
      </tabGroup>
    </splitPane>
  </documents>
</xamDockManager>
