Hello, just recently we incorporated your controls into our application. So far looks good! Except I notice that I'm getting the following exception when adding a TabItemEx to the xamTabControl with the CloseButtonVisibility property set to TabItemCloseButtonVisibility.WhenSelectedOrHotTracked. Any ideas on what could be causing this?
Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Infragistics.Windows.Controls.ToolWindow', AncestorLevel='1''. BindingExpression:Path=IsActive; DataItem=null; target element is 'Button' (Name='CloseButton'); target property is 'NoTarget' (type 'Object')
Thanks!
Hello Collin,
This issue is currently still in development. I have created case CAS-90580-MVCNN3 for you and will link the case to the development issue so that you will be notified of any changes.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
Has there been any development on this? I'm finding myself bit with it as well using 2011.1 under Windows 7 x64. Thank you!
I was able to replicate the issue you are seeing, and I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 105410. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution. I will leave this case open and update you with this information after the review.
I will create a private case for you to notify of any changes to this issue.
Sincerely,
Valerie
Infragistics, Inc
Please let me know about the environment you are working in so that I can try to reproduce the issue.
Running your sample I get the following:System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Infragistics.Windows.Controls.ToolWindow', AncestorLevel='1''. BindingExpression:Path=IsActive; DataItem=null; target element is 'Button' (Name='CloseButton'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Infragistics.Windows.Controls.ToolWindow', AncestorLevel='1''. BindingExpression:Path=IsActive; DataItem=null; target element is 'Button' (Name='CloseButton'); target property is 'NoTarget' (type 'Object')System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Infragistics.Windows.Controls.ToolWindow', AncestorLevel='1''. BindingExpression:Path=IsActive; DataItem=null; target element is 'Button' (Name='CloseButton'); target property is 'NoTarget' (type 'Object')
