Let me start by saying I'm using the latest v9.1 data grid with AllowRecordFiltering set to True. When I try to setup a custom filter, by choosing "custom" on the combobox, I get this nice "Custom Filter Selection" screen, however, when I click on the screen and try to move it or cancel the application crashes. My WPF user control is being hosted on a win32 form using ElementHost. Any help would be greatly appreciated.
Here is the stack trace.
" at Infragistics.Windows.Controls.ToolWindowHostPopup.GetWorkArea(MouseEventArgs e)\r\n at Infragistics.Windows.Controls.ToolWindowHostPopup.OnEnteringMove(MouseEventArgs e)\r\n at Infragistics.Windows.Controls.ToolWindowContainer.Infragistics.Windows.Controls.IToolWindowHost.DragMove(MouseEventArgs e)\r\n at Infragistics.Windows.Controls.ToolWindow.OnPartMouseLeftButtonDown(Object sender, MouseButtonEventArgs e)\r\n at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)\r\n at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)\r\n at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)\r\n at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)\r\n at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)\r\n at System.Windows.UIElement.CrackMouseButtonEventAndReRaiseEvent(DependencyObject sender, MouseButtonEventArgs e)\r\n at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)\r\n at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)\r\n at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)\r\n at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)\r\n at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)\r\n at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)\r\n at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)\r\n at System.Windows.Input.InputManager.ProcessStagingArea()\r\n at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)\r\n at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)\r\n at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)\r\n at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)\r\n at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)\r\n at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)\r\n at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)\r\n at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)\r\n at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)\r\n at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)\r\n at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter)\r\n at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg)\r\n at MS.Win32.HwndSubcl***bclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)\r\n at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)\r\n at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)\r\n at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)\r\n at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)\r\n at System.Windows.Forms.Application.Run(Form mainForm)\r\n at CEM.Launch.Main() in D:\\TFSC\\CUDL\\CEM\\Projects\\CEM.Launcher\\Launch.cs:line 23"
Any update for this case number? CAS-22096-WFBH3G
The issue has been logged and is currently in development.
JBeytia - you will be notified when it is resolved and the service release is out.
zhuwei - I am going to create a support case on your behalf and link it to the same issue so that you will be notified as well.
zhuwei - I haven't heard anthing from them.
Infragistics - If any Infragistics employees are actually reading this, can someone provide some feedback.
Hi JBeytia,
I'm seeing the same issue. Have you heard anything from your ticket?
Hi rmking,
The case number is CAS-22096-WFBH3G. I am waiting for a response and will post as soon as I receive one.
regards,
jbeytia
