410
Column binding for multiple fields
Hello, I believe this has been addressed already just from reading several of the posts but I just wanted to confirm after providing some code I used when using the standard WPF grid controls.  I am trying to concatenate more than one field and bind that to a column.
For example if i have three fields:  Source Return, Source Client ID and finally Return Name and I would like "Source Return" to be the combination of two fields, say "sourceClientID" and "sourceReturnVersion" how can I accomplish this in the xaml?
As I mentioned above, I previously could accomplish this in the old grid by implementing the following:
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
<GridViewColumn Header="Origin Name">
       <GridViewColumn.CellTemplate>
              <DataTemplate>
                     <StackPanel Orientation="Horizontal">
                            <TextBlock Text="{Binding SourceClientID}"/>
                            <TextBlock Text=":"/>
                           <TextBlock Text="{Binding SourceReturnVersion}"/>
                     </StackPanel>
              </DataTemplate>
       </GridViewColumn.CellTemplate>
</GridViewColumn>
Is there anyway to do something similar to this in the xaml for xamDatagrid?  In a previous post it was said that this could not be accomplished in the xaml but could be accomplished by utlilizing RecordUpdated and InitializeRecord events.
I sincerely apologize if i'm doubling up on a post, but it is imperitive that I'm clear on this.  Thank you all so much!
  • 69686
    You can use the DataItem and create a style like this:
    <Style x:Key="TwoColumnStyle" TargetType="{x:Type igDP:CellValuePresenter}">
                <Setter Property="Template">
                    <Setter.Value>
                        <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                                <TextBlock Text="{Binding Path=DataItem.FirstName}"/>
                               <TextBlock Text="+"/>
                                <TextBlock Text="{Binding Path=DataItem.LastName}"/>
                            </StackPanel>
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
            </Style>
    Alex.
