I have a series set in xaml
<igCA:Series x:Name="Series1" ChartType="StackedColumn" ..... />
<igCA:Series x:Name="Series2" ChartType="StackedColumn" .... />
What I do in code is return a dataset back and set the datasource and datamapping in code:
sub chart_loaded (....
..series(1).datasource= dsObject
..series(1).datamapping = "Label=Date; Value=Amount"
end sub
The reason I am doing this is that I have markup code with animations, set the styles, chartypes, etc. already set for the series and did not want to do this in code.
The question I have is - If I do not want to graph the second series, I dont set the datasource or datamapping. The problem is, it (the data) will not display on the chart, BUT the series color will display in the Legend.
Is there something I can do so that if I do not wish to utilize the additional series, I can remove it so that it will not display on the legend?
i think that's the best solution.
I think I found the answer:
chart.series.remove(chart.series(2))
