1531
Setting Field ValueConstraint in code (not xaml)
Does anyone know how to set a value constraint in code (preferably C#)?  I want to set or change the max data length of a column in code when the form is loaded based on values in a table.  It was suggested on this form to use the construct show below in xaml.  That worked perfectly as a first step, but now I need to be able to do the same thing in code.
Any ideas?
Steve Wall
<igDP:FieldSettings.EditorStyle>
    <Style TargetType="igEditors:XamTextEditor">
        <Setter Property="ValueConstraint">
            <Setter.Value>
                <igEditors:ValueConstraint MaxLength="15"/>
            </Setter.Value>
        </Setter>
    </Style>
</igDP:FieldSettings.EditorStyle>
