I'm trying to programmatically set the selected item in a gallery tool. It works when I look at the properties in the debugger. This doesn't seem to do much else, however: The ItemSelected event is not triggered, and when I click on the button to see the gallery items, the one I set as selected is not highlighted.
Is there some kind of magic involved in doing this, or is it a bug? My gallery in XAML is patterned after the one from the XamFeatureBrowser - nothing particularly fancy (I want to use it as a theme selector.)
Thanks,Michel
Thanks for the feedback. Setting the SelectedItem should probably be setting the IsSelected of the associated item. Maybe we can address this in a future build.
OK, that works. I was doing this:
ThemesGallery.SelectedItem = _themeItem
(Where "_themeItem" is a GalleryItem object obtained through a For Each construct)
I reworked the code a little and now I do this:
ThemesGallery.Items(_themesIndex).IsSelected = True
...And the event gets triggered properly *and* the item appears selected in the gallery - we're in business! This looks much better than a ComboEditorTool that simply lists the names of the various themes.
I was under the impression that setting SelectedItem would yield the same result (and it never occurred to me to try setting IsSelected instead - I guess I'm fighting on too many fronts this week. :))
Thanks a lot for your help!Michel
I tried this out and setting the IsSelected of the GalleryItem (e.g. this.gallery.Items[0].IsSelected = true;) did raise the ItemSelected event (assuming that its IsSelected wasn't already true). If you're not seeing the same behavior then its possible there was a fix in this area in which case I would recommend getting the latest hotfix - you may need to contact the support group.
Andrew Smith"] You probably need to set the ItemBehavior to StateButton. Otherwise it will just act like a button which will invoke the ItemClicked event and not show any selection state.
Hi Andrew,
It was already set to StateButton. I also tried Button, just in case. No event gets triggered when assigning SelectedItem programmatically, in both cases. I tried these events: ItemSelected, ItemActivated, ItemClicked. Works fine when selecting a gallery item using the mouse, but that's not good enough here (on startup, I read the last theme used from the config file and need to set it programmatically.)
Any idea?
