165
IsEnabled=false makes internal cell controls visible
when I set grid.IsEnabled = false the borders around text boxes in cells become visible which doesn't look great.
Any ideas how to fix it? I need grid to be grayed out and nothing else.
  • 69686
    For the solution of this problem I used very handy tool - Snoop, which helps you see the visual tree of the grid. By creating a style, targeting the xamTextEditor you can set the BorderThickness property to 0 and remove the gray borders around the text boxes. You can see the default xamTextEditor template in your "~\Infragistics\NetAdvantage for WPF 2008 Vol. 2\DefaultStyles\Editors" folder.
     Here is the style that I used:
    <Style TargetType="{x:Type igEditors:XamTextEditor}">
                    <Setter Property="BorderThickness" Value="0" />
    </Style>
