Hi
I have question with hierarchical grid.
In hierarchical grid we are using the + / - for expand and collapse the grid.
I want to place a next to minus (-) sign image (Like folder open image) when that grid expanding mode.
and change the (next to + plus sign) image (Like folder close image) automatically when that grid collapsing.
you help is highly appreciated. thanks.
by
ramesh
Hello David,
Thank you for your post. I have been looking into it and I have modified the sample that Alex uploaded in the forum thread you provided, so now it works as you want. If you group by the second field the expansion indicators will be different. Basically I used converters in the Images’ Source Properties to set a different picture depending on which Fields is grouped and whether it is grouped at all.
Hope this helps you.
Hi Alex, I know that this post (http://community.infragistics.com/forums/p/18938/81442.aspx#81442) was some time ago now, but it would be really useful if this example could be extended to show how the plus/minus images could be different depending on which field was grouped...so that I can do something like explorer where the icon displayed is different depending on the folder type that is being expanded.
David
Yes, the best way to do this is in the InitializeRecord event set
e.Record.IsExpanded = true;
Alex.
Hi Alex,
Is there any way which always keeps the expander as expanded by default.
