926
multiple grouping in xamdatagrid
How can we get the multiple grouping done in xamdatgrid ?Rather I need a hierarchail data in the grid.
My resultsets from the service gives me all the records in a plain gridview.I need to group it by "Name" and "Submitted on" fields.And I need both the fields on the same line. Can we do this ?
I am trying to bind xamdatagrid using WCF service.
Code in WCF service:
Public Function Raise_Request_Records_Summary(ByVal Completion_Level As Int16) As DataTable Implements WCF_Service_Pay_Raise_Request.Raise_Request_Records_Summary
Dim Result As DataTable = New DataTable
Try
Dim TempTable As New DataTable
Dim SQL_Statement As String = "EXEC STORED PROCEDURE"
Dim MySQLConnection As New SqlClient.SqlConnection(AcctTools_Connection)
Dim MySQLCommand As New SqlClient.SqlCommand(SQL_Statement, MySQLConnection)
MySQLCommand.Parameters.Add("@Completion_Level", SqlDbType.VarChar, 5)
MySQLCommand.Parameters(0).Value = Completion_Level
Dim MyDataAdapter As New SqlClient.SqlDataAdapter(MySQLCommand)
MyDataAdapter.Fill(TempTable)
Result = TempTable.Clone
'Cleanup!
MyDataAdapter.Dispose()
MySQLCommand.Dispose()
MySQLConnection.Dispose()
Catch ex As Exception Report_Error("An error occurred while looking up the Pay Raise record summary. The message was: " + ex.Message)
End Try
Result.TableName = "Raise_Request_Records_Summary"
Return Result
End Function
CODE IN THE PAGE_LOADED:
Dim Completion_Level As Int16 = 2
If chk_Hide_Closed.IsChecked Then Completion_Level = 1
Dim Client As New AEDEV_WCF.AEDEV_Service_Pay_Raise_RequestClient Dim Display_Table As DataTable = Client.Raise_Request_Records_Summary(Completion_Level)
Client.Close()
XamDataGrid1.DataSource = Display_Table.Rows
I NEED GRID TO DISPLAY THIS:
Band1: Name(ABC), Submitted on
Band2: All the data under(ABC)
How can I achieve this ?
  • 28464
    I think what you need is documented here:
    Programmatically Sort and Group Fields
    http://help.infragistics.com/Help/NetAdvantage/WPF/2008.2/CLR3.X/html/xamData_Programmatically_Sort_and_Group_Fields.html
    using Infragistics.Windows.DataPresenter;
    FieldSortDescription deptSort = new FieldSortDescription();
    deptSort.Direction = System.ComponentModel.ListSortDirection.Descending;
    deptSort.FieldName = "department";
    deptSort.IsGroupBy = true;
    FieldSortDescription salarySort = new FieldSortDescription();
    salarySort.Direction = System.ComponentModel.ListSortDirection.Descending;
    salarySort.FieldName = "salary";
    //Code for xamDataGrid
    this.xamDataGrid1.FieldLayouts[0].SortedFields.Clear();
    this.xamDataGrid1.FieldLayouts[0].SortedFields.Add(deptSort);
    this.xamDataGrid1.FieldLayouts[0].SortedFields.Add(salarySort);
    //Code for xamDataCarousel
    this.xamDataCarousel1.FieldLayouts[0].SortedFields.Clear();
    this.xamDataCarousel1.FieldLayouts[0].SortedFields.Add(deptSort);
    this.xamDataCarousel1.FieldLayouts[0].SortedFields.Add(salarySort);
    //Code for xamDataPresenter
    this.xamDataPresenter1.FieldLayouts[0].SortedFields.Clear();
    this.xamDataPresenter1.FieldLayouts[0].SortedFields.Add(deptSort);
    this.xamDataPresenter1.FieldLayouts[0].SortedFields.Add(salarySort);
