I want to let the user to reArrange the displayed records
by making drag and drop between records could any one tell me the first steps to do that
Is there still no simple way to do drag and drop between two grids?
Hello, you could see a simple example of Drag and Drop in the article here http://forums.infragistics.com/blogs/alex_fidanov/archive/2009/07/28/drag-amp-drop-with-datapresenter-family-controls.aspx
Hope this helps.
Horen Kirazyan
Can't wait till we have better feature parity with the winform ultragrid.
Shrenik,
Thanks for this. The sample looks great. Moreover, you can check out the "official" way of implementing Drag-Drop by handling the built-in events for that. You can find the sample here: http://blogs.infragistics.com/blogs/alex_fidanov/archive/2009/07/28/drag-amp-drop-with-datapresenter-family-controls.aspx
Thanks for this sample, Its really good starting point. I found some issue with this sample like:
1. DataRecordPresenter will return null if Field is not editable
2. When we need to drag-drop some times autoscroll also required.
3. LazyLoad is not resolving the issue of disappering Visual.
4. Drop indication...
I have updated your sample. and posting here back for future user benefits.
Attached sample solved all above problem by creating all the fields as editable but not editable :) which can be applied at individual field level.
Regards
Shrenik
