I'd like to have the header of each group show in 11 points, but I would like the title of the group that appears at the top of the xamOutlookbar to appear in 16 points. I'm having trouble figuring out how to do this. Any ideas?
Hello Anastas,,
I modified your project to manage external events (see attachment)
((TextBlock)this.Resources["OutLookTitle"]).Text = "Some Text";
Regards, Lello
Looks like we replied almost at the same time :)
Hello Lello,
See at the attached project. All I do is to copy and paste the defaultStyle for SelectedGroupHeader in XAML(this style is available in DefaultStyles folder in install folder), and one converter which adds the "Selected Group:" string.
If you want to display some text once(regardless of groups selection) you can change this row in style
Content="{Binding Path=(igOutlookBar:XamOutlookBar.OutlookBar).SelectedGroup.Header, RelativeSource={RelativeSource Self},Converter={StaticResource converter}}"
with something other like:
Content="Some Text"
Anastas
Dear Anastas,I found this solution ...Is there a simpler solution than this?
<Style TargetType="{x:Type OutlookBar:SelectedGroupHeader}">
<Style.Resources>
<RotateTransform x:Key="MinimizeOnRightTransform" Angle="180"/>
</Style.Resources>
<Setter Property="Background" Value="{DynamicResource {x:Static OutlookBar:OutlookBarBrushKeys.CurrentGroupHeaderCenterFillKey}}"/>
<Setter Property="BorderBrush" Value="{DynamicResource {x:Static OutlookBar:OutlookBarBrushKeys.GroupInnerBorderFillKey}}"/>
<Setter Property="Foreground" Value="{DynamicResource {x:Static OutlookBar:OutlookBarBrushKeys.HeaderDarkTextFillKey}}"/>
<Setter Property="SnapsToDevicePixels" Value="True"/>
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type OutlookBar:SelectedGroupHeader}">
<Grid Margin="0,0,0,1">
<Border
Background="{TemplateBinding Background}"
BorderBrush="{TemplateBinding BorderBrush}"
BorderThickness="{TemplateBinding BorderThickness}"
SnapsToDevicePixels="{TemplateBinding SnapsToDevicePixels}">
<Grid>
<Grid.ColumnDefinitions>
<ColumnDefinition Width="*"/>
<ColumnDefinition Width="Auto"/>
</Grid.ColumnDefinitions>
<ContentPresenter
x:Name="ContentPresenterHeader"
Grid.Column="0"
Content= "This is My custom Text bla bla bla..."
Margin="7,7,8,3"/>
<ToggleButton
x:Name="MinimizeButton"
Visibility="Visible"
Grid.Column="1"
IsChecked="{Binding Path=(OutlookBar:XamOutlookBar.OutlookBar).IsMinimized, RelativeSource={RelativeSource Self}}"
IsEnabled="{Binding Path=(OutlookBar:XamOutlookBar.OutlookBar).AllowMinimized, RelativeSource={RelativeSource Self}}"
Style="{DynamicResource {x:Static OutlookBar:XamOutlookBar.MinimizeToggleButtonStyleKey}}"
Margin="0,4,0,3"/>
</Grid>
</Border>
<Border x:Name="innerBorder" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="1,1,0,0"/>
<ControlTemplate.Triggers>
<DataTrigger Binding="{Binding Path=OutlookBar.IsMinimized, RelativeSource={RelativeSource TemplatedParent}}" Value="True">
<Setter TargetName="ContentPresenterHeader" Property="Visibility" Value="Collapsed"/>
</DataTrigger>
<DataTrigger Binding="{Binding Path=OutlookBar.VerticalSplitterLocation, RelativeSource={RelativeSource TemplatedParent}}" Value="Left">
<Setter TargetName="MinimizeButton" Property="LayoutTransform" Value="{StaticResource MinimizeOnRightTransform}"/>
</ControlTemplate.Triggers>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
Hello Anastas,
Thanks for the reply.I would like to change the text in SelectedGroupHeader with a text other than the button text.
