1650
Master-Detail Grid show invalid detail data: Styles not re-evaluated
Hi there
 Another issue, this time with master-detail binding. First, let me explain the layout as seen in the screenshot below:
- If a node in the tree is being selected, the upper grid's data source is being changed programmatically (no binding).
- the lower grid is part of a user control. This user control's data context is bound to the upper grid's active record. Thus, if I select another record in the upper grid, the lower grid displays related data.
- If data was changed, the cells display an icon (marked with red circels, you might have to view the image in a new browser window if the forum crops them). Whether or not this icon is visible depends on a style that uses a converter.
The first image display a proper rendering. I changed the data source of the upper grid by selecting a tree item. This causes the lower grid to be updated and the styles are evaluated (converter is being invoked for each cell):
However, if the main grid's data source remains and i just select another record, the lower grid's DATA is being updated (marked by blue circle), but not the CellValuePresenter styles! As you can see, the indcators just stay there. Breakpoints in the debugger confirm that the converter is not being invoked again, although the grid's data source changed due to the binding:
I'm getting a little nervous here: I have a grid that renders wrong data all over the place and my customers expect a working version by next week, so any idea is greatly appreciated Sad
Thanks for your advice
Philipp
