1080
Changing to tab containing xamDataGrid very slow
I'm currently evaluation NetAdvantage for WPF. I created a little test application which uses a xamDockManager to implement a tabbed user interface. At the moment I have two tabs: an empty one and one with a xamDataGrid which displays data from an SQL Server database.
Unfortunately switching from the empty tab to the tab containing the xamDataGrid takes around 2 seconds, which is rather slow. I reduced the number of rows in the grid from 1700 to 50 and the columns from 30 to 15, but this had no effect on the speed of changing tabs. If I reduce the number of rows to 0, switching between the tabs is rather fast. So it seem's that drawing the xamDataGrid makes things slow.
Any idea what the problem could be? How can I improve the speed of switching tabs?
Best Regards
 Markus
<igDock:ContentPane Name="contentPane1" TabHeader="Pane 1" AllowFloatingOnly="True" AllowPinning="True" >
<Grid Name="MainContentGrid">
<Grid.RowDefinitions>
<RowDefinition Height="*" />
<RowDefinition Height="60" />
</Grid.RowDefinitions>
<igDP:XamDataGrid HorizontalAlignment="Stretch" Name="xamMainDataGrid" VerticalAlignment="Stretch" Grid.Row="0"
BindToSampleData="False" Theme="Office2k7Blue" RecordActivated="xamMainDataGrid_RecordActivated"
IsNestedDataDisplayEnabled="False" RecordLoadMode="LoadOnDemand" RecordContainerGenerationMode="Recycle"
UpdateMode="OnUpdate">
</igDP:XamDataGrid>
<Grid Name="DetailsGrid" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Grid.Row="1">
<Grid.ColumnDefinitions>
<ColumnDefinition />
</Grid.ColumnDefinitions>
<RowDefinition></RowDefinition>
<igRibbon:LabelTool Name="LabelManufacturer" Caption="Manufacturer:" HorizontalAlignment="Right" Grid.Row="0" Grid.Column="0"/>
<igEditors:XamTextEditor Name="xamTextEditorManufacturer" Grid.Row="0" Grid.Column="1" Theme="Office2k7Blue">
</igEditors:XamTextEditor>
<igRibbon:LabelTool Name="LabelManPartNo" Caption="Manufacturer PartNo:" HorizontalAlignment="Right" Grid.Row="1" Grid.Column="0"/>
<igEditors:XamTextEditor Name="xamTextEditorManPartNo" Grid.Row="1" Grid.Column="1" Theme="Office2k7Blue">
<igRibbon:LabelTool Name="LabelDatasheet" Caption="Datasheet:" HorizontalAlignment="Right" Grid.Row="2" Grid.Column="0"/>
<igEditors:XamTextEditor Name="xamTextEditorDatesheet" Grid.Row="2" Grid.Column="1" Theme="Office2k7Blue">
<igRibbon:LabelTool Name="LabelCreatedBy" Caption="Created by:" HorizontalAlignment="Right" Grid.Row="0" Grid.Column="2"/>
<igEditors:XamTextEditor Name="xamTextEditorCreatedBy" Grid.Row="0" Grid.Column="3" Theme="Office2k7Blue">
<igRibbon:LabelTool Name="LabelCreationDate" Caption="Creation date:" HorizontalAlignment="Right" Grid.Row="1" Grid.Column="2"/>
<igEditors:XamTextEditor Name="xamTextEditorCreationDate" Grid.Row="1" Grid.Column="3" Theme="Office2k7Blue">
</Grid>
</Grid>
</igDock:ContentPane>
