70
applying style DataRecordCellArea dynamically
I have a list of objects implementing INotifyPropertyChange bound to a Grid (particularly CSLA objects).  One of the properties is called IsValid and responds true if there is any error on the object.
 I've applied the following style
<Style TargetType="{x:Type igDP:DataRecordCellArea}">
<Style.Triggers>
<DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.DataItem.IsValid, UpdateSourceTrigger=PropertyChanged, ValidatesOnDataErrors=True}" Value="False">
<Setter Property="Background" Value="Red" />
<Setter Property="FontWeight" Value="Bold" />
</DataTrigger>
<DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.DataItem.IsValid}" Value="True">
<Setter Property="Background" Value="Green" />
</DataTrigger>
</Style.Triggers>
</Style>
 I also have a textbox outside of the grid bound to a field of the active record.  When I put invalid data in this field, I can see the grid update with the same info, but it doesn't trigger the red background.  If I scroll the record out of view and back into view, it then displays a red background.  How do I set it up to display the red background when the data becomes invalid?
