240
I want to display hierarchial data
structure of my data is follows. it has 3 depth data.
class Panel
    int panelid;
    sting panelname;
   ObservableCollection<console> consoles;
class Console
   int panelid;
   int consoleid;
   string consolename;
   ObservableCollection<Sound> sounds;
class Sound
   int consoleid;
   int soundid;
   string sounddata;
// data provider
public ObservableCollection<Panel> GetPanelList()
     ObservableCollection<Panel> retVal = new ObservableCollection<Panel>();
     for ( int i = 0; i < 10; i++ )
         Panel panel = new Panel();
         panel.panelid  = i;
         panel.consoles = new ObservableCollection<Console>();
         for ( int j = 0; j < 10; j++ )
             Console console = new Console();
             console.panelid = i;
             console.consoleid = j
             console.sounds = new ObservableCollection<Sound>();
             for ( int k = 0; k < 10; k++ )
                 Sound sound = new Sound();
                 sound.consoleid = j;
                 sound.soundid = k;
                 console.sounds.add(sound);
             panel.consoles.add(console);
so, i had binding the Panels(ObservableCollection<Panel>) at XamDataGird.
however, my XamDataGrid  can display just 2 level data.
my FieldLayout of XamDataGrid is follows.
        <igDP:XamDataGrid x:Name="panelInfoGrid" DataSource="{Binding Path=PanelList, Mode=TwoWay}" AutoFit="True">
            <igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:FieldLayoutSettings AutoGenerateFields="False"/>
            </igDP:XamDataGrid.FieldLayoutSettings>
            <igDP:XamDataGrid.FieldLayouts>
                <!-- Panel Information-->
                <igDP:FieldLayout >
                    <igDP:FieldLayout.Fields>
                        <igDP:Field Name="panelid" Label="panelid" IsScrollTipField="True" Visibility="Collapsed"/>
                        <igDP:Field Name="panelname" Label="name"/>
                    </igDP:FieldLayout.Fields>
                </igDP:FieldLayout>
                <!-- Console Information -->
                <igDP:FieldLayout>
                        <igDP:Field Name="panelid" Label="panelid" Visibility="Collapsed"/>
                        <igDP:Field Name="consoleid" Label="consoleid" Visibility="Collapsed"/>
                        <igDP:Field Name="consolename" Label="consolename"/>
                </igDP:FieldLayout>
                <!-- Sound Information -->
                <igDP:FieldLayout>
                        <igDP:Field Name="soundid" Label="soundid"/>
                        <igDP:Field Name="soundname" Label="soundname"/>
                </igDP:FieldLayout>
I want to display 3 level hierarchial data when  AutoGenerateFields="False"
How can i do this??
  • 3627
    I didn't try your example, but I'm surprised the xaml field definitions shown work. I've always had to define a "link" field that enables a child table.
    In your panels field layout, I'd think you'd need:
    <igDP:Field Name="consoles" />
    And then in your consoles field layout:
    <igDP:Field Name="sounds" />
