I have a cube that I am quering for CellSets and I would like to display the data in the Grid. I will limit the number of Axes returned by the CellSet to 2 so the grid can display it in tabular format, but I would like to know if it is possible to show the hierarchical structure of the of the selected dimension members in the row and header column as follows:
50
5657
45
2342345
66
656
74
23454
226
23234
76
2342
123245
78
15664
The layout of the multiple field columns headers in the XamDataGrid > Layout and Behavior > Record Layout Customization example that you mention is what I am looking for, but the example has cell values for each field header displayed. My data on the other hand has one value that relates to to the combination of field headers. In my original post I showed the scenario where record header of "Division 1 - > Store 1" had 1 cell value per measure column, not a cell value for Division 1 and then an additional cell value for Store 1 under that division.
I can try to clarify if this still doesn't make sense. Also, can you create the same type of headers for each row as well? Here is a mock up of what I am trying do do with the record headers in black and white, and the actual cell values in a blue background
Thanks for any help.
Shane
You can put multiple field headers in one column. The xamFeatureBrowser application, which is installed when you install NetAdvantage for WPF, has a demo of this. Under XamDataGrid > Layout and Behavior > Record Layout Customization
The grid in that demo is declared as:
<igDP:XamDataGrid Grid.Row="1" x:Name="XamDataGrid1" DataSource="{Binding Source={StaticResource QuarterbackData}, XPath=season}"> <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AutoArrangeCells="Never" AutoGenerateFields="False"/> </igDP:XamDataGrid.FieldLayoutSettings> <igDP:XamDataGrid.FieldLayouts> <igDP:FieldLayout> <igDP:FieldLayout.Fields> <igDP:Field Name="team" Label="Team" Row="0" Column="0" ColumnSpan="5" /> <igDP:Field Name="games" Label="Games Played" Row="1" Column="0"/> <igDP:Field Name="qbrate" Label="Rating" Row="1" Column="1"/> <igDP:Field Name="comp" Label="Completions" Row="1" Column="2"/> <igDP:Field Name="att" Label="Attempts" Row="1" Column="3"/> <igDP:Field Name="pct" Label="Passing %" Row="1" Column="4"/> <igDP:Field Name="passingyards" Label="Total Passing Yards" Row="2" Column="0" /> <igDP:Field Name="passingyardsperattempt" Label="Passing Yards/Attempt" Row="2" Column="1" /> <igDP:Field Name="passingyardspergame" Label="Passing Yards/Game" Row="2" Column="2" /> <igDP:Field Name="passingtd" Label="Passing Touchdowns" Row="2" Column="3" /> <igDP:Field Name="int" Label="Interceptions" Row="2" Column="4" /> <igDP:Field Name="rushs" Label="Rushes" Row="3" Column="0" /> <igDP:Field Name="rushyrds" Label="Rushing Yards" Row="3" Column="1" /> <igDP:Field Name="rushyardspergame" Label="Rushing Yard/Game" Row="3" Column="2" /> <igDP:Field Name="rushavg" Label="Rushing Average" Row="3" Column="3" /> <igDP:Field Name="rushtd" Label="Rushing Touchdowns" Row="3" Column="4" /> <igDP:Field Name="sack" Label="Sacks" Row="4" Column="0" /> <igDP:Field Name="yardslost" Label="Yards Lost" Row="4" Column="1" /> <igDP:Field Name="fum" Label="Fumbles" Row="4" Column="2" /> <igDP:Field Name="fuml" Label="Fumbles Lost" Row="4" Column="3" /> </igDP:FieldLayout.Fields> </igDP:FieldLayout> </igDP:XamDataGrid.FieldLayouts> </igDP:XamDataGrid>
Josh
