Is there a way to change the text alignment of the summary records to be right aligned?
I've tried the following
<igDP:XamDataGrid.Resources>
<Style TargetType="{x:Type igDP:SummaryRecordPresenter}">
<Setter Property="HorizontalContentAlignment" Value="Right"/>
<Setter Property="HorizontalAlignment" Value="Right"/>
</Style>
</igDP:XamDataGrid.Resources>
But haven't had the desired results
Hello Pete,
If the style has no Key set, then it would automatically apply to any summary result presenter, no matter how it is generated.
Josh,
How does one attach the style to the dynamically-generated SummaryResultPresenter?
Pete
I think this is what you're looking for...
<!-- This Style right-aligns the summary display text. --> <Style TargetType="{x:Type igDP:SummaryResultPresenter}"> <Setter Property="HorizontalAlignment" Value="Right" /> <Setter Property="Margin" Value="0,0,4,0" /> </Style>
Josh
