Hi all,
Currently I'm using xamDataGrid 8.1 Express edition, so far I found out that this a nice component. And I want to suggest my company to buy the non-Express edition for our current project.
However rignt now I'm having problem with it.
Here's how to repro the problem: Disabled the xamDataGrid, change the datasource, re-enabled the xamDataGrid.
And here's the code snipped:
List<A> listA = new List<A>(); A a = new A(); a.stringA = "testA1"; listA.Add(a); a = new A(); a.stringA = "testA2"; listA.Add(a); // bind the xamdatagrid xamDataGrid1.DataSource = listA; // disable the xamdatagrid xamDataGrid1.IsEnabled = false; A a2 = new A(); a2.stringA = "added new"; listA.Add(a2); // rebind the xamdatagrid xamDataGrid1.DataSource = null; xamDataGrid1.DataSource = listA; // re enable the datagrid xamDataGrid1.IsEnabled = true;
The problem is that some of the row are still disabled, cannot be clicked, but can access those row using the keyboard up and down keys.
Is this a bug or did I do something wrong? since I'm new in WPF and xamlDataGrid. :P
Any help or work arround would be really appreciated... and sorry for my English :P
Thanks in advance
Hi Josh,
Thank you for your solution. It works fine. However lately I found out that with RecordContainerGenerationMode property set to LazyLoad, I facing a problem with the scrollbar.
The scrollbar (gradually) disapear when I scroll down to the bottom and then scroll up the grid...
Is there any other work arround for this problem?
That looks like a bug, thanks for pointing it out. To work around it, you can either not disable the grid when reseting the data source, or set the grid's RecordContainerGenerationMode property to LazyLoad.
Josh
