240
how to create dynamic cell editor?
i using the xamDataGrid. i want to create dynamic cell editor... for example, when i click cell #2, if the value of the cell #1 is 3, i want to display the editor for date and time, and if the value of the cell #1 is 4, i want to display the editor for custom data.
  • 6867
    Verified Answer
    I think the following technique should satisfy your requirement...
    <Window.Resources>
      <Style x:Key="VariableCellEditorStyle" TargetType="{x:Type igDP:CellValuePresenter}">
        <Style.Triggers>
          <DataTrigger Binding="{Binding Path=Cells[SomeField].Value}" Value="0">
            <Setter Property="Template">
              <Setter.Value>
                <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                  <TextBox
                    Background="LightBlue"
                    Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}"
                </ControlTemplate>
              </Setter.Value>
            </Setter>
          </DataTrigger>
          <DataTrigger Binding="{Binding Path=Cells[SomeField].Value}" Value="1">
              <Setter.Value>
                  <igEditors:XamTextEditor
                    Background="Gray"
                    IsReadOnly="True"
                    Value="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}"
                </ControlTemplate>
              </Setter.Value>
            </Setter>
          </DataTrigger>
        </Style.Triggers>
      </Style>
    </Window.Resources>
    <igDP:XamDataGrid x:Name="xamDG">
      <igDP:XamDataGrid.FieldLayouts>
        <igDP:FieldLayout>
          <igDP:FieldLayout.Fields>
            <igDP:Field Name="State">
              <igDP:Field.Settings>
                <igDP:FieldSettings CellValuePresenterStyle="{StaticResource VariableCellEditorStyle}" />
              </igDP:Field.Settings>
            </igDP:Field>
          </igDP:FieldLayout.Fields>
        </igDP:FieldLayout>
      </igDP:XamDataGrid.FieldLayouts>
    </igDP:XamDataGrid>
    Josh
