Sachab,
I was looking at your example and was wondering if you could send me the source code of you example.
Bryan
I found this approach to be the easiest by far Say I had a xamDatagrid bound like this, using the following test class
public class TestClass { public Int32 Id { get; set; } public String Name { get; set; } public String Department { get; set; } public override string ToString() { return string.Format("{0} {1} {2}", Id, Name, Department); } }
And the grid datasource was like this
List<TestClass> classes = new List<TestClass> { new TestClass { Id = 1, Department ="xyz1", Name = "Grrr1"}, new TestClass { Id = 2, Department ="xyz2", Name = "Grrr2"}, new TestClass { Id = 3, Department ="xyz3", Name = "Grrr3"} }; dgSearchResults.DataSource = classes;
And then I set some styles like this.
<igDP:XamDataGrid x:Name="dgSearchResults" Margin="0" Theme="RoyaleStrong" Visibility="Visible" Background="{DynamicResource mainControlAreaBackGround}"> <igDP:XamDataGrid.Resources> <ControlTemplate x:Key="RoundToolTip" TargetType="{x:Type ToolTip}"> <Grid > <Grid.RowDefinitions> <RowDefinition Height="Auto" /> </Grid.RowDefinitions> <Grid.ColumnDefinitions> <ColumnDefinition Width="Auto" /> </Grid.ColumnDefinitions> <Rectangle RadiusX="5" RadiusY="5" Fill="Black" Stroke="Black" StrokeThickness="1" /> <Grid > <Grid.RowDefinitions> <RowDefinition Height="3" /> <RowDefinition Height="*" /> <RowDefinition Height="3" /> </Grid.RowDefinitions> <Grid.ColumnDefinitions> <ColumnDefinition Width="3"/> <ColumnDefinition Width="*" /> <ColumnDefinition Width="3"/> </Grid.ColumnDefinitions> <Border Grid.Column="1" Grid.Row="1"> <StackPanel> <ContentControl Content="{TemplateBinding Content}" /> </StackPanel> </Border> </Grid> </Grid> </ControlTemplate> <Style TargetType="{x:Type ToolTip}"> <Setter Property="Template" Value="{StaticResource RoundToolTip}" /> </Style> <ContentControl x:Key="ToolTipContent" Background="Transparent"> <Border HorizontalAlignment="Stretch" BorderBrush="Black" Background="White" Margin="0" Grid.Row="0" Grid.Column="2" VerticalAlignment="Stretch" Height="260" Opacity="0.95" BorderThickness="5" CornerRadius="3" > <Grid> <Grid.RowDefinitions> <RowDefinition Height="Auto" /> <RowDefinition Height="*"/> </Grid.RowDefinitions> <Grid.ColumnDefinitions> <ColumnDefinition Width="*" /> <ColumnDefinition Width="Auto"/> </Grid.ColumnDefinitions> <StackPanel Background="Black" Orientation="Horizontal" HorizontalAlignment="Stretch"> <Label VerticalAlignment="Stretch" HorizontalAlignment="Stretch" Background="Black" FontSize="18" Foreground="White" Grid.ColumnSpan="2">Payment</Label> <Label VerticalAlignment="Stretch" HorizontalAlignment="Stretch" Background="Black" FontSize="18" Foreground="White" Grid.ColumnSpan="2" Content="{Binding Path=Cells[Id].Value}"></Label> <Label VerticalAlignment="Stretch" HorizontalAlignment="Stretch" Background="Black" FontSize="18" Foreground="White" Grid.ColumnSpan="2">history:</Label> </StackPanel> <StackPanel Grid.Row="1"> <StackPanel Orientation="Horizontal"> <Label Content="Full content"/> <Label Content="{Binding}"/> </StackPanel> </StackPanel> </Grid> </Border> </ContentControl> <Style TargetType="{x:Type igDP:DataRecordPresenter}"> <Setter Property="ToolTip" Value="{DynamicResource ToolTipContent}" /> </Style> </igDP:XamDataGrid.Resources> <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AutoGenerateFields="True" /> </igDP:XamDataGrid.FieldLayoutSettings> </igDP:XamDataGrid>
Now considering how useful a tooltip is why the heck does it have to be this hard, it just shouldn't be that hard.
Josh,
There is another way to approach this, don't use any styles and just do it in the code-behind directly.
Bolow is the sample code:
private void OnMouseMove(object sender, System.Windows.Input.MouseEventArgs e) // this is a mouse over event handler for XamDataGrid { DataRecordPresenter drp = Infragistics.Windows.Utilities.GetAncestorFromType(e.OriginalSource, typeof(DataRecordPresenter), true) as DataRecordPresenter;
if (drp == null) { return; }
// //TODO: show your tool tip, you can use reflection to get your current underlying data record, for example: // StringBuilder toolTip = new StringBuilder(); string label = string.Empty; // // Especially if you are using Linq as your underling data source, then reflection is // the unique way to get the values of kinds of fields. Type type = drp.DataRecord.DataItem.GetType(); System.Reflection.PropertyInfo[ pInfos = type.GetProperties();
foreach (System.Reflection.PropertyInfo pi in pInfos) { label = xamDataGrid.FieldLayouts[0].Fields[pi.Name].Label.ToString(); // xamDataGrid is your XamDataGrid control name. toolTip.Append(label); toolTip.Append(": "); toolTip.Append(pi.GetValue(drp.DataRecord.DataItem, null)); toolTip.Append(Environment.NewLine); } drp.ToolTip = toolTip.Length > 0 ? toolTip.ToString() : null; }
Hope this helps.
Corin
If you look at the sample, you can see the following binding:
ToolTip="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Record.DataItem.EditStatus}"
The DataItem expression points to my underlying business object, which means you have access to all properties. So if I wanted to display the value of the field Name in the tooltip as well, I could just change it to something like this:
<ToolTip> <StackPanel Orientation="Horizontal"> <TextBlock Text="Editor Status of field " /> <TextBlock Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Record.DataItem.Name}" FontWeight="Bold" /> <TextBlock Text="is " /> <TextBlock Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Record.DataItem.EditStatus}" /> </StackPanel> </ToolTip>
Does this answer your question?
Cheers,
Philipp
