Hi!
Does someone know how I can highlight the sorted Column of my Grid? If I click on the header of a column it is sorted automatically and then a small arrow is displayed next to the header, so you know that the grid is sorted by this column. But I like to highlight the whole column that is sorted at the moment.
Can someone help me please?
Thx
Where/how do these Styles get used?
Thanx, Rob
Thank you, that works great!
Hi.
I used this to highlight the cells:
<Style x:Key="GridCell" TargetType="{x:Type dataPresenter:CellValuePresenter}">
<Setter Property="BorderBrush" Value="#EDEDEB"/>
<Setter Property="BorderThickness" Value="1"/>
<Style.Triggers>
<Trigger Property="SortStatus" Value="Ascending">
<Setter Property="Background" Value="#F7FAFE"/>
</Trigger>
<Trigger Property="SortStatus" Value="Descending">
</Style>
And this to highlight the header:
<Style x:Key="GridHeader" TargetType="{x:Type dataPresenter:LabelPresenter}">
<Setter Property="Foreground" Value="#333333"/>
<Setter Property="Background">
<Setter.Value>
<LinearGradientBrush StartPoint="0,0" EndPoint="0,1">
<GradientStop Color="#FCFCFC" Offset="0" />
<GradientStop Color="#EFEFEF" Offset="1" />
</LinearGradientBrush>
</Setter.Value>
</Setter>
<Setter Property="Background" Value="#E9EFF9"/>
</Style.Triggers>
Maybe you will need to set other colors for more visibility. Hope this helps.
Nico
