3627
TIP: How to use CellValuePresenterStyle
I've found no documentation on this functionality. It didn't work exactly as I expected, but I was able to cobble it together. Specifically, I expected the current item to be passed into the item argument of the StyleSelector, but it was not. Instead, I had to drill down into the container object to get at the DataItem.
So, here is an example of defining three styles, each representing a different icon. The intent is to display the correct icon in an unbound field, depending on a proprty of the domain object being displayed.
From the xaml inside the XamDataGrid:
<igDP:XamDataGrid.Resources>
    <Style x:Key="UnmappedIconStyle" TargetType="{x:Type igDP:CellValuePresenter}">
        <Setter Property="Template">
            <Setter.Value>
                <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                    <ContentControl Template="{StaticResource UnmappedIcon}" />
                </ControlTemplate>
            </Setter.Value>
        </Setter>
    </Style>
    <Style x:Key="MappedIconStyle" TargetType="{x:Type igDP:CellValuePresenter}">
            <Setter.Value>
                    <ContentControl Template="{StaticResource MappedIcon}" />
                </ControlTemplate>
            </Setter.Value>
        </Setter>
    </Style>
    <Style x:Key="SuggestedIconStyle" TargetType="{x:Type igDP:CellValuePresenter}">
            <Setter.Value>
                    <ContentControl Template="{StaticResource SuggestedIcon}" />
                </ControlTemplate>
            </Setter.Value>
        </Setter>
    </Style>
    <ui:MappableEntityIconStyleSelector x:Key="IconStyleSelector"
                                        UnmappedStyle="{StaticResource UnmappedIconStyle}"
                                        MappedStyle="{StaticResource MappedIconStyle}"
                                        SuggestedStyle="{StaticResource SuggestedIconStyle}" />
</igDP:XamDataGrid.Resources>
<igDP:XamDataGrid.FieldLayouts>
    <igDP:FieldLayout>
        <igDP:FieldLayout.Fields>
            <igDP:UnboundField Name="MapStatusIcon" >
                <igDP:Field.Settings>
                    <igDP:FieldSettings AllowResize="false"
                                        CellValuePresenterStyleSelector="{StaticResource IconStyleSelector}"
                                                        CellContentAlignment="ValueOnly"
                                                        CellMaxWidth="18"
                                                        CellMinWidth="18" />
                </igDP:Field.Settings>
            </igDP:UnboundField>
And here is the StyleSelector:
using System.Windows;
using System.Windows.Controls;
using MappingTool.Domain;
using Infragistics.Windows.DataPresenter;
namespace MappingTool.Presentation
    public class MappableEntityIconStyleSelector : StyleSelector
        public Style UnmappedStyle { get; set; }
        public Style MappedStyle { get; set; }
        public Style SuggestedStyle { get; set; }
        /// <summary>
        /// Returns the style to display a mappable entity's icon with in the grids.
        /// </summary>
        /// <param name="item"></param>
        /// <param name="container"></param>
        /// <returns></returns>
        public override Style  SelectStyle(object item, DependencyObject container)
            Style style = UnmappedStyle;
            CellValuePresenter cvp = container as CellValuePresenter;
            if (cvp != null)
                MappableEntity entity = cvp.Record.DataItem as MappableEntity;
                if (entity != null)
                    switch (entity.MapStatus)
                        case MappableEntity.MapStatusEnum.Mapped:
                            style = this.MappedStyle;
                            break;
                        case MappableEntity.MapStatusEnum.Suggested:
                            style = this.SuggestedStyle;
                            break;
            return style;
If anyone can shed any light on why the item is not being passed in, or of a better way to acocmplish this, I'd like to hear about it.
