15
XamDataGrid : Dynamic Column with two controls( Button, TextBox) not firing edit event
I Have a XamDataGrid and i am adding dynamic columns .
Able to add the columns but when i try edit the text in the column it is not firing DatGrid edit event
Please help me on how to trigger fire event when enter data in text box
Grid Design
<igDP:XamDataGrid Grid.Row="3" Name="SubmissionGrid" Margin="5,5,5,5" Style="{StaticResource EventCreationXamDGStyle}" RecordsDeleting="SubmissionGrid_RecordsDeleting"
DataValueChanged="SubmissionGrid_DataValueChanged" EditModeStarting="SubmissionGrid_EditModeStarting" EditModeStarted="SubmissionGrid_EditModeStarted" EditModeEnding="SubmissionGrid_EditModeEnding" RecordAdded="SubmissionGrid_RecordAdded" KeyUp="SubmissionGrid_KeyUp" RecordsDeleted="SubmissionGrid_RecordsDeleted" RecordAdding="SubmissionGrid_RecordAdding" >
<igDP:XamDataGrid.Resources>
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Style.Triggers>
<DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Field.Name}" Value="Rec #">
<Setter Property="HorizontalContentAlignment" Value="Center"/>
</DataTrigger>
</Style.Triggers>
</Style>
</igDP:XamDataGrid.Resources>
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings AllowAddNew="True" AllowDelete="True" AddNewRecordLocation="OnBottom" AutoGenerateFields="False" AutoArrangePrimaryFieldReservation="None"/>
</igDP:XamDataGrid.FieldLayoutSettings>
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout>
<igDP:FieldLayout.Fields>
<igDP:UnboundField Name="deleteField" Width="40">
<igDP:UnboundField.Settings>
<igDP:FieldSettings  AllowResize="False" AllowGroupBy="False" AllowRecordFiltering="False" AllowSummaries="False"
   CellMaxWidth="20" CellValuePresenterStyle="{StaticResource deleteButtonforEventCreationStyle}"/>
</igDP:UnboundField.Settings>
</igDP:UnboundField>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts>
</igDP:XamDataGrid>
Adding dynamic columns with below code
Here is the cellpresentervalue style
