We have implemented XML editor with provided XML syntax code generated by Infragistics Sample for custom language from EBNF. The example has inbuilt XML code but we face a minor error shown in our XML text:
I've tried to do research on EBNF file and looks a little bit suspicious the exclusion character classes since < and > are text blocks so I believe regex definition might be wrong in the provided EBNF code of the Infragistics sample:
Please help to eliminate this error from XML syntax parser since this is false positive. After adding lookup on grammar errors I see fallowing errors generated by syntax editor control:
This looks like a bug to me , i am going to investigate it with the team and would log it into our bug tracking system.
For now i have created a private case C-00226943 to communicate with you and also to link the bug.
You can access the private case from your Infragoistics account support section.
