Xaml
<igWPF:XamDockManager> <igWPF:DocumentContentHost> <igWPF:SplitPane Width="auto" Height="auto" SplitterOrientation="Vertical"> <igWPF:TabGroupPane ItemsSource="{Binding TabGroupItems}"> <=== binding success <igWPF:TabGroupPane.ContentTemplate> <DataTemplate> <igWPF:XamDataGrid DataSource={Binding DataGridItems> <==== how to binding?? <igWPF:XamDataGrid.FieldLayoutSettings> <igWPF:FieldLayoutSettings AutoGenerateFields="False"/> </igWPF:XamDataGrid.FieldLayoutSettings> <igWPF:XamDataGrid.FieldLayouts> <igWPF:FieldLayout> <igWPF:FieldLayout.SortedFields> <igWPF:FieldSortDescription Direction="Descending" FieldName="RegisterNumber"/> </igWPF:FieldLayout.SortedFields> <igWPF:FieldLayout.Fields> <igWPF:Field Name="RegisterNumber" Label="Register Number" AllowEdit="False" Width="*"/> <igWPF:Field Name="RegisterAddress" Label="Register Address" AllowEdit="False" Width="*"/> <igWPF:Field Name="ItemName" Label="Item Name" AllowEdit="False" Width="*"/> <igWPF:Field Name="Authority" Label="Authority" AllowEdit="False" Width="*"/> <igWPF:Field Name="MinRange" Label="Min Range" AllowEdit="False" Width="*"/> <igWPF:Field Name="MaxRange" Label="Max Range" AllowEdit="False" Width="*"/> <igWPF:Field Name="Value" Label="Value" AllowEdit="False" Width="*"/> <igWPF:Field Name="Request" Label="Request" AllowEdit="False" Width="*"/> </igWPF:FieldLayout.Fields> </igWPF:FieldLayout> </igWPF:XamDataGrid.FieldLayouts> </igWPF:XamDataGrid> </DataTemplate> </igWPF:TabGroupPane.ContentTemplate> </igWPF:TabGroupPane> </igWPF:SplitPane> </igWPF:DocumentContentHost> </igWPF:XamDockManager>
It was successful until creating a Tab by binding the Contentpane to the TabGrouppane. But. I wanted to display the Xamdatagrid inside each tab, but it was not possible. What should I do?
Hello Kim,
The data context of the elements within the TabGroupPane.ContentTemplate will be the ContentPane in this case. I am guessing that your TabGroupItems collection is a collection of ContentPanes in this case? If this is the case, I would recommend that whatever object you are setting to your ContentPane.Content property has the DataGridItems collection on it. Doing this should allow you to bind to Content.DataGridItems on the XamDataGrid and bind the data source that way.
