We have encountered a new issue in the spreadsheet control when performing the Undo command (reproduced in the attached sample application). We have named references in the workbook which are updated dynamically (static references applied to entire column currently do not work in the spreadsheet control). In order to simplify the update of the reference, we use R1C1 reference style. When undo operation is performed for named reference update, an exception is thrown.
Steps to reproduce:
This issue seems to be independent of whether R1C1 style is enabled in the workbook or not.
Is there any workaround for this issue?
SpreadsheetUndoReferenceIssueSample.zip
Hello Tomas,
I can reproduce the behavior and I created a private support case to continue our discussion (# CAS-213975-Q8Y7K5), and in addition I will be transitioning this over for our developers to review as well. You can access it after signing into your account on the Infragistics website, here: https://es.infragistics.com/my-account/support-activity.
