1240
Evenly distributing Docking / Split Panes
I’m trying to achieve what I thought to be a fairly simple task, create three panes and distribute them evenly vertically within a dock manager.  Basically a top, middle and bottom pane, each taking up 1/3 of the window.  I have researched and looked over the sample app, but still can’t achieve what I’m trying to do.  The following are two of my many attempts at achieving this.  Perhaps I’m using the RelativeSize incorrectly.  Any help with this is greatly appreciated.
Dan
    <!-- Transfers Dock Manager -->
    <RCSSharedUIExtensions:XamDockManagerEx Grid.Row="1" x:Name="TransfersDockManager3" Focusable="false">
      <igDock:XamDockManager.Panes>
        <!-- Split Pane 1 (top 1/3) -->
        <igDock:SplitPane igDock:SplitPane.RelativeSize="100,300" igDock:XamDockManager.InitialLocation="DockedTop" SplitterOrientation="Horizontal">
          <!-- Split Pane 1, Content Pane 1 -->
          <igDock:ContentPane
            x:Name="InboundTransfersContentPane3">
            <igDP:XamDataGrid
              x:Name="PART_InboundTransfersBangList3"
              DataSource="{Binding Tracker.InboundDataList.UICollection}">
            </igDP:XamDataGrid>
          </igDock:ContentPane>
        </igDock:SplitPane>
        <!-- Split Pane 2 (second 1/3) -->
        <igDock:SplitPane igDock:SplitPane.RelativeSize="100,300" SplitterOrientation="Horizontal">
          <!-- Split Pane 2, Content Pane 1 -->
          <igDock:ContentPane
            x:Name="OutboundTransfersContentPane3">
            <igDP:XamDataGrid
              x:Name="PART_OutboundTransfersBangList3"
              DataSource="{Binding Tracker.OutboundDataList.UICollection}">
            </igDP:XamDataGrid>
        </igDock:SplitPane>
        <!-- Split Pane 3 (bottom 1/3) -->
        <igDock:SplitPane igDock:SplitPane.RelativeSize="100,300"  igDock:XamDockManager.InitialLocation="DockedBottom" SplitterOrientation="Horizontal">
          <!-- Split Pane 3, Content Pane 1 -->
          <igDock:ContentPane
            x:Name="NexGenTransfersContentPane3"
            CloseAction="HidePane"
            Header="{Binding Tracker.NexGenDataList.Count, Converter={StaticResource StringFormatConverter}, ConverterParameter='NexGen Transfers ({0})'}"
            Style="{StaticResource OnAirContentPaneStyle}">
            <igDP:XamDataGrid
              x:Name="PART_NexGenTransfersBangList3"
              DataSource="{Binding Tracker.NexGenDataList.UICollection}">
            </igDP:XamDataGrid>
        </igDock:SplitPane>
      </igDock:XamDockManager.Panes>
    </RCSSharedUIExtensions:XamDockManagerEx>
    <RCSSharedUIExtensions:XamDockManagerEx Grid.Row="1" x:Name="TransfersDockManager2" Focusable="false">
        <igDock:SplitPane igDock:SplitPane.RelativeSize="100,100" igDock:XamDockManager.InitialLocation="DockedTop" SplitterOrientation="Horizontal">
          <igDock:ContentPane
            x:Name="InboundTransfersContentPane2">
            <igDP:XamDataGrid
              x:Name="PART_InboundTransfersBangList2"
            </igDP:XamDataGrid>
        </igDock:SplitPane>
        <!-- Split Pane 2 (bottom 2/3) -->
        <igDock:SplitPane igDock:SplitPane.RelativeSize="100,200" igDock:XamDockManager.InitialLocation="DockedBottom" SplitterOrientation="Horizontal">
          <!-- Split Pane 3 (Top of bottom pane which is split into 2) -->
          <igDock:SplitPane igDock:XamDockManager.InitialLocation="DockedTop" SplitterOrientation="Horizontal">
            <!-- Split Pane 3, Content Pane 1-->
            <igDock:ContentPane
              x:Name="OutboundTransfersContentPane2">
              <igDP:XamDataGrid
                x:Name="PART_OutboundTransfersBangList2"
              </igDP:XamDataGrid>
          </igDock:SplitPane>
          <!-- Split Pane 4 (Bottom of bottom pane which is split into 2) -->
          <igDock:SplitPane igDock:XamDockManager.InitialLocation="DockedBottom" SplitterOrientation="Horizontal">
            <!-- Split Pane 4, Content Pane 1-->
            <igDock:ContentPane
              x:Name="NexGenTransfersContentPane2"
              <igDP:XamDataGrid
                x:Name="PART_NexGenTransfersBangList2"
              </igDP:XamDataGrid>
          </igDock:SplitPane>
        </igDock:SplitPane>
  • 7555
    Verified Answer
    Hello Daniel,
    Thank you for contacting . If you want three panes that equally fill the available area then you would have to use a single SplitPane to contain all three panes and you would set the xamDockManager’s LayoutMode property to "FillContainer.
    Something like this :
    <igDock:XamDockManager Name="xamDockManager1" LayoutMode="FillContainer" >
    <igDock:ContentPane x:Name="InboundTransfersContentPane3">
    <igDP:XamDataGrid
    BindToSampleData="True" >
    </igDP:XamDataGrid>
    <igDock:ContentPane x:Name="OutboundTransfersContentPane3">
    <igDP:XamDataGrid
    BindToSampleData="True">
    </igDP:XamDataGrid>
    <igDock:ContentPane
    Header="Test">
    <igDP:XamDataGrid
    </igDP:XamDataGrid>
    </igDock:SplitPane>
    The FillContainer will take the innermost split pane and fill the remaining area and RelativeSize on a root splitpane would no nothing , it only affects how panes within a SplitPane are sized by comparing its values to the siblings. At the root the SplitPanes are positioned either based on the Width/Height or barring that then their preferred size
    Let me know if you have any question.
