1415
XamlMultiColumnComboEditor Reset Button
Reset button works (clears text field) when the text represents and item within the list.
But, when the text does not match an item in the list, it doesn't clear the text field.  Is it possible to add this as part of the reset button click?
For instance, I type "test" and no matches are found (because CustomValueEnteredAction="Add")
When clicking the "X" reset button, I would like the text field to clear.  Currently, it appears disabled due to no matching value in the list.
  • 140
    I have investigated your issue with the xamMultiColumnComboEditor reset button not working correctly, and I have asked our engineering staff to examine this further.  To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 271884.  The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
    I will leave this case open and update you with any new information after the review.  You can also continue to send updates to this case at any time.
    You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
    Please let me know if you need more information.
    Your private support case is cas 210316 l1t6y2
