850
Saved filter not being applied
Hi, I have a xamdatagrid which saves column layout and filters. The layout is restored but the saved filters are ignored.
Field I want filtered
                            <igDP:Field Name="VolumeNumber"
                                        Label="Volume"
                                        Width="60"
                                        HorizontalContentAlignment="Center">
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings>
                                        <igDP:FieldSettings.CellValuePresenterStyle>
                                            <Style TargetType="{x:Type igDP:CellValuePresenter}">
                                                <Setter Property="Foreground"
                                                        Value="{Binding Path=Cells[VolumeNumber].Value, Converter={StaticResource MyValueToColorConverter}}">
                                                </Setter>
                                            </Style>
                                        </igDP:FieldSettings.CellValuePresenterStyle>
                                    </igDP:FieldSettings>
                                </igDP:Field.Settings>
                            </igDP:Field>
Preferences loading code
        private void FillList()
            StatusList = new RequestStatus();
            RequestCollection = new VolumeRequestCollection(uc.FacilityGUID, null);
            string gridLayout = DataAccess.GetGridPreferences(uc.UserIDCode, uc.FacilityGUID, "requests");
            if(!string.IsNullOrEmpty(gridLayout))
                dgRequests.LoadCustomizations(gridLayout);
Saved filter
			<recordFilters>
				<RecordFilter FieldName="VolumeNumber">
					<ConditionGroup LogicalOperator="And">
						<ComparisonCondition Operator="NotEquals" Value="0" />
					</ConditionGroup>
				</RecordFilter>
			</recordFilters>
Peter
