Please help there is no data in the drop down in the combobox field in the xamdatagrid this only thing it show that it is a collection
I have this class ```` public class AvisTIlGrid { public int BureaoOrdreNr { get; set; } public decimal Total { get; set; } public int UgeavisID { get; set; } public string bureauOrdreNr { get; set; }
public List<Fejl> fejl { get; set; }
} ````````public class Fejl { private string fejltekst;
public string FejlTekst { get => fejltekst; set => fejltekst = value; } }````And in a Dao Class the fejl is populated with data from the FejlTekstTable ```fejl = diMPdot.tblFejlTeksts.Select( f => new Fejl() { FejlTekst = f.FejlTekst }).ToList()
````The result from the query looks like this its a List<Fejl> Ingen valgt Bestilt for sent - ikke bragt Ordre ikke modtaget Glemt annonce DLU har fremsendt forkert matr. Vi har indrykket forkert matr. Forkert farve Forkert placering Forkert annonce format Glemt farve````````
And in my view class I have a XamDataGrid where Specify a ComboBoxField but when I run the code there is no data in the dropdown memu
```` <igWPF:ComboBoxField Name="fejl" DisplayMemberPath="FejlTekst" Label="Fejl" > </igWPF:ComboBoxField>
The rest of the values is showing find in the textfields in the xamdatagrid
Hello Thomas,
I have been looking into your question and created a small sample with a XamDataGrid and a ComboBoxField containing a list of objects as per your class structure.
Since the property List<Fejl> fejl is a member of the AvisTIlGrid data model, every AvisTIlGrid object instance is associated with its own List<Fejl> fejl property. Therefore, the ComboBoxField’s ItemsSource should be set to the corresponding DataItem’s fejl property. This can be achieved by defining an EditorStyle targeting the XamComboEditor and adding a Setter for the ItemsSource. The DataContext of the XamComboEditor in the Cell is the DataRecord and the ItemsSource can be bound to its DataItem:
<igWPF:ComboBoxField Name="fejl" Label="Fejl" DisplayMemberPath="FejlTekst" ValuePath="FejlTekst" BindingType="Unbound"> <igWPF:ComboBoxField.Settings> <igWPF:FieldSettings> <igWPF:FieldSettings.EditorStyle> <Style TargetType="{x:Type igWPF:XamComboEditor}"> <Setter Property="ItemsSource" Value="{Binding DataItem.fejl}"/> </Style> </igWPF:FieldSettings.EditorStyle> </igWPF:FieldSettings> </igWPF:ComboBoxField.Settings> </igWPF:ComboBoxField>
You can find the sample attached below. If you require any further assistance on the matter, please let me know.
Sincerely,
Bozhidara Pachilova,
Associate Software Developer
5736.XDGWithComboField.zip
