I have the IGWord project up and running and working fine.
I am trying to modify it so that we can pass a path to a document on startup.
This is working in that it calls the OnFileLoaded method, set the title etc but no text is shown. There is text in the document but nothing is displayed. If I add text and save that works fine. The wordData property is being set and the editor is visible.
Can anyone help on why the text is not showing?
Thanks.
What control are you using to view the document? We do not have a control that can be used as a word viewer. You can use our Word library to open a file in memory, modify it, generate a new one and save it only.
Can you please provide more information on the app you have(maybe some steps to recreate the issue in a blank app so we can see what may be wrong?).
Looking forward to your reply.
Sincerely,Tihomir TonevAssociate Software DeveloperInfragistics
