I would like user able to move column with up/down buttons
User selected column must be visible to the user
I added up/down buttons on the right side of this dialog
Clicking on the up/down arrow button the column should move inside the FieldChooser dialog
when user ticked the selected column checkbox the grid column order sync with FieldChooser dialog column order
Please provide me any sample application to implment this feature
(up/down arrow buttons or drag & drop)
Please help ASAP
Kanex.Siva
Hello Kanex,
In order to move columns you can use the following method:
this.grid1.FieldLayouts[0].FieldItems.Move(oldPosition, oldPosition + 1); <- moving a column to the left.
during the same event, calling the FieldChooser FieldDisplayOrder will update the order in the FC.
Regarding selection, from where do you perform it?
What happens if a column reaches the end? does it go the begining.
What is the visual confirmation you are looking tor?
Sincerely,
Tihomir TonevAssociate Software DeveloperInfragistics
