I have a XamComboEditor like so
<ig:XamComboEditor Name="cmbProviderList" EmptyText="--ALL--" AllowMultipleSelection="True" Width="245" Margin="0,0,0,20" HorizontalAlignment="Left" ItemsSource="{Binding ProviderList}" DisplayMemberPath="DisplayName" SelectedValuePath="DisplayName"/>
I'm setting the SelectedValues in code behind like so
object[] providers = new object[userPullListParameters.ProviderName.Count]; for (int i = 0; i < userPullListParameters.ProviderName.Count; i++) { providers[i] = userPullListParameters.ProviderName[i]; } cmbProviderList.SelectedValues = providers;
I can verify that the object array contains 3 strings, however only the last item in the array ends up set in the combobox.
Peter
I'm glad to know that you don't have the problem now.
Thanks for the response. I've ended up taking a completely different approach. Although I do essentially the same thing in my new code, I don't have the problem anymore. Was certainly something I missed.
Hello Peter Friebel,
I created a sample which used your codes as much as possible and gave it a try, but your issue wasn't reproduced.I attached it to this response.Could you take a look at it and see if it works expectedly on your side?
2656.F121506-SampleApp1.zip
