How do I remove the purple and yellow borders around the legend icons (left of the "Waiting" "Running" text)
I am glad that you find my suggestion helpful.Thank you for using Infragistics components.
Teodosia HristodorovaAssociate Software Developer
Thank you! I think my borders are coming from the "Metro" theme that is applied, but your XAML fixed this for me
I have created a small sample trying to reproduce the described behavior. I'm using Infragistics WPF v19.2 and there is no border by default.
However, what I can suggest you is re-templating the Series's LegendItemTemplate. In this case, you will be able to override the look of each legend item as per your requirement.
<ig:StepAreaSeries.LegendItemTemplate> <DataTemplate> <Grid Margin="0, 5, 10, 0"> <Grid.ColumnDefinitions> <ColumnDefinition/> <ColumnDefinition/> </Grid.ColumnDefinitions> <Ellipse Grid.Column="0" Margin="0, 0, 5, 0" StrokeThickness="0" Fill="{Binding Series.ActualBrush}" Width="15" Height="15" /> <TextBlock Grid.Column="1" VerticalAlignment="Center" Text="{Binding Series.Title}" /> </Grid> </DataTemplate> </ig:StepAreaSeries.LegendItemTemplate>
By changing the Ellipse Stroke and StrokeTickness properties, you can change the border color and thickness as you need. When the StrokeTickness is set to 0 there would be no border.
Attached you will find my sample for your reference. Please test it on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me along with steps to reproduce. Alternatively, if the behavior cannot be replicated please feel free to provide your own sample. Remove any external dependencies and code that is not directly related to the issue, zip your application and attach it in this case.
Having a working sample on my side, which I can debug, is going to be very helpful in finding the root cause of this behavior.
Thank you for your cooperation.
Sincerely,
2867.XamDataChart_LegendItem_No_Border.zip
