280
Floating content panes has no border
I trying to create a MDI application in WPF, using the XamDocManager. Loading different "windows" in a tabgrouppane works as intended, but if I want to change a pane to floating, it will not create a "windows" border around the content pane. By making a content pane floating, I would expect to get a window border around it.
Is this intended? Is it an windows issue? Is there a solution to make it work?
I would also like to prevent any floating content pane to move outside the main window. Is there a way to solve this too?
Does the docmanager also prevents windows, i.e. dialog windows opened from a content pane, from having it's normal window border? For me, this is the case, wich also seem odd. Any advice in this case?
Below are two images hopefully showing what I mean.
/ FW
