40
Exception: "The root Visual of a VisualTarget cannot have a parent" with XamRibbonWindow
Hello
We recently had an exception with a strange call stack that just showed some method in the XamRibbonWindow.
Maybe someone else also had this issue and can give any advise as to what may be causing the exception.
The scenario was the following: The user was working in Outlook or Excel and was then moving the mouse over our application window (which was open in the background). While doing that the exception occurred. The user was also working with our application under Citrix.
(Windows 10, .NET 4.7.2 (4.7.3429.0), Citrix: 4.6.0.12010, Infragistics: 16.1)
Thanks for any advise or suggestions.
Karsten
The complete call stack is:
System.ArgumentException: The root Visual of a VisualTarget cannot have a parent.
at System.Windows.Media.CompositionTarget.SetRootVisual(Visual visual)
at System.Windows.Media.CompositionTarget.set_RootVisual(Visual value)
at System.Windows.Interop.HwndTarget.set_RootVisual(Visual value)
at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
at System.Windows.Window.SetRootVisual()
at System.Windows.Window.SetRootVisualAndUpdateSTC()
at System.Windows.Window.SetupInitialState(Double requestedTop, Double requestedLeft, Double requestedWidth, Double requestedHeight)
at System.Windows.Window.CreateSourceWindow(Boolean duringShow)
at System.Windows.Window.ShowHelper(Object booleanBox)
at Infragistics.Windows.Ribbon.XamRibbonWindow.VerifyExternalResizeWindows()
at Infragistics.Windows.Ribbon.XamRibbonWindow.HookProc(IntPtr hwnd, Int32 message, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.PublicHooksFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
