530
Add and delete column to datagrid dynamically
I like to dynamically add and delete column to the xamdatadatagrid.
To illustrate I have 3 list.
FirstList, secondlist, mainlist.
First and second list is empty.
Mainlist have some values.
I want to add column for the main list for every item that are added in first and second list.
How can add those filed dynamically and handle the binding?
Here is my sample code
<Grid>
        <StackPanel>
            <igDP:XamDataGrid
                DataSource="{Binding FirstList}" GroupByAreaLocation="None" Margin="5">
                <igDP:XamDataGrid.FieldLayoutSettings>
                    <igDP:FieldLayoutSettings AutoFitMode="Always"
                                              AddNewRecordLocation="OnTopFixed"
                                              AllowAddNew="True"
                                              SupportDataErrorInfo="RecordsAndCells"
                                              DataErrorDisplayMode="Highlight"
                                              AutoGenerateFields="False"
                </igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:XamDataGrid.FieldLayouts>
                    <igDP:FieldLayout>
                        <igDP:Field Name="Name"/>
                        <igDP:Field Name="Value"></igDP:Field>
                    </igDP:FieldLayout>
                </igDP:XamDataGrid.FieldLayouts>
            </igDP:XamDataGrid>
            <igDP:XamDataGrid
                DataSource="{Binding SecondList}" GroupByAreaLocation="None" Margin="5" RecordAdded="SecondList_OnRecordAdded">
                                              AllowAddNew="True"
                    <igDP:FieldLayout>
                        <igDP:CheckBoxField Name="Selected"></igDP:CheckBoxField>
                    </igDP:FieldLayout>
            </igDP:XamDataGrid>
            <igDP:XamDataGrid
           DataSource="{Binding Data}"
           FieldLayoutInitialized="XamDataGrid_FieldLayoutInitialized" GroupByAreaLocation="None">
                    <igDP:FieldLayoutSettings AutoGenerateFields="False"
                                              AddNewRecordLocation="OnBottomFixed"
                                              AllowAddNew="True"
                                              DataErrorDisplayMode="Highlight"/>
                    <igDP:FieldLayout>
                        <igDP:UnboundField BindingPath="Parameters[0].Value"/>
                    </igDP:FieldLayout>
            </igDP:XamDataGrid>
        </StackPanel>
    </Grid>
 public class MainViewModel
        public MainViewModel()
            Data = new ObservableCollection<MyViewModel>();
            FirstList = new ObservableCollection<FirstClass>();
            FirstList.CollectionChanged += FirstList_CollectionChanged;
            SecondList = new ObservableCollection<SecondClass>();
            SecondList.CollectionChanged += SecondList_CollectionChanged;
            Random r = new Random();
            int inner = r.Next(5, 15);
            for (int i = 0; i < 10; i++)
                MyViewModel vm = new MyViewModel()
                    Name = "Name " + i,
                    Parameters = new List<Parameter>()
                for (int j = 0; j < inner; j++)
                    vm.Parameters.Add(new Parameter { ParameterName = "Parameter " + j, Value = r.Next(10000).ToString() });
                Data.Add(vm);
        private void SecondList_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
            //Add and delete dynamic column to the MyViewModel
        private void FirstList_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
            //Add and Delete dynamic column to the MyViewModel
        public ObservableCollection<MyViewModel> Data { get; set; }
        public ObservableCollection<FirstClass> FirstList { get; set; }
        public ObservableCollection<SecondClass> SecondList { get; set; }
    public class MyViewModel
        public string Name { get; set; }
        public List<Parameter> Parameters { get; set; }
    public class Parameter
        public string ParameterName { get; set; }
        public string Value { get; set; }
 public class FirstClass : BaseNotifier
        private string _name;
        private double _value;
        public String Name
            get { return _name; }
            set
                _name = value;
                OnPropertyChanged(nameof(Name));
        public double Value
            get { return _value; }
            set
                _value = value;
                OnPropertyChanged(nameof(Value));
        public FirstClass(string name, double value)
            Name = name;
            Value = value;
     public class SecondClass : BaseNotifier
        private bool _selected;
        public String Name
            set
                _name = value;
        public bool Selected
            get { return _selected; }
            set
                _selected = value;
                OnPropertyChanged(nameof(Selected));
        public SecondClass(string name, bool selected)
            Name = name;
            Selected = selected;
    public partial class MainWindow : Window
        MainViewModel vm;
        public MainWindow()
            InitializeComponent();
            vm = new MainViewModel();
            DataContext = vm;
        private void XamDataGrid_FieldLayoutInitialized(object sender, Infragistics.Windows.DataPresenter.Events.FieldLayoutInitializedEventArgs e)
            MyViewModel elem = vm.Data.First();
            for (int i = 0; i < elem.Parameters.Count; i++)
                UnboundField field = new UnboundField
                    Name = elem.Parameters[i].ParameterName,
                    BindingPath = new PropertyPath("Parameters[" + i + "].Value")
                e.FieldLayout.Fields.Add(field);
        private void SecondList_OnRecordAdded(object sender, RecordAddedEventArgs e)
            //Initialize the new created item depending on current configuration of method/reflection
            var viewModel = DataContext as MainViewModel;
            if (viewModel != null)
                viewModel.SecondList.Add(e.Record.DataItem as SecondClass);
