Is there an equivalent to the CalloutLayer of the xamDataChart with the xamScatterSurface3D?
I Need to Display additional info at 3D Point positions.
Regards Horst
Hello Horst,
Thank you for the update. Unfortunately, currently, we dont have CalloutLayer in xamScatterSurface3D.
But you can create a new feature idea for the future version at <http://ideas.infragistics.com>.
Thank you in advance to submitting your product idea.
Divya Jain
Hello Divya,
Using markers would not work because markers to my knowledge indicate every data point of the 3D model. I only want to indicate special points of interest.
Overlaying a 2D callout is not an option because the 3D chart might be rotated zoomed etc. thus synchronization would be impossible.
Summarizing, the xamScatterSurface3D is not usable for my project.
Thank you for posting. In xamScatterSurface3D we have marker which you may use , having CalloutLayer in xamScatterSurface3D would be a new product idea.
Although you can try putting a datachart over the scatter surface and project your data into 2d to use the callout layer in the datachart.
Let me know if you have any question.
Regards,Divya JainAssociate S/W developer
