150
ItemTemplateSelector for RadialMenuItem
Hi. I was wondering if there is a simple way to implement an itemtemplateselector property for the RadialMenuItem?
I have the following:
<XamRadialMenu>
<ig:RadialMenuItem
Visibility="{Binding HasContextualItems, Converter={StaticResource BoolToHiddenVisibility}}"
IsEnabled="{Binding HasContextualItems}"
ToolTip="{Binding ContextualMenuHeader}"
Header="{Binding ContextualMenuHeader}" Command="{Binding OpenCommand}"
CommandParameter="{Binding RelativeSource={RelativeSource Self}}"
OuterRingButtonFill="{Binding ContextualMenuBrush}"
OuterRingButtonHotTrackFill="{Binding ContextualMenuHotTrackBrush}"
ItemsSource="{Binding ContextualMenuItems}"
AutoUpdateRecentItem="False"> // Here instead of explicitly using one itemContainderTemplate i'd like to use a selector
<ig:RadialMenuItem.ItemContainerTemplate>
<DataTemplate DataType="local:ContextualMenuItem">
<ig:RadialMenuItem CheckBehavior="CheckBox"
Header="{Binding Header}"
ToolTip="{Binding Header}"
Command="{Binding Command}"
OuterRingButtonFill="{Binding Brush}"
OuterRingButtonHotTrackFill="{Binding HotTrackBrush}"
ItemsSource="{Binding Items}"
Visibility="{Binding UseMtvPresetListDataTemplate, Converter={StaticResource InvBoolToVisibility}}">
CommandParameter="{Binding RelativeSource={RelativeSource Self}}" />
</DataTemplate>
</ig:RadialMenuItem.ItemContainerTemplate>
</ig:RadialMenuItem>
</DataTemplate>
<XamRadialMenu>
Thanks for the help!
Nathan
  • 7535
    Hello Nathan,
    Thank you for posting. After investigating itemtemplateselector property for the RadialMenuItem and doing some research, itemtemplateselector in built support for RadialMenuItem has been determined to be a new feature idea. You can suggest new feature ideas for future versions (or vote for existing ones) at <ideas.infragistics.com>.
    Best thing I can probably recommend to try is that you builds the DataTemplates externally and gives them an x:Key. Doing that, you can get those templates programmatically and assign them. Completely spit-balling though, don't really know if that would work out of the box, for us in-built support of that in a new feature idea.
    Sincerely,
    Divya Jain
    Associate Software Developer
