15
XamDataChart Multiple Binding errors when creating Y axes in code behind
Hi
I'm having an issue since I updated to 18.2 (was priori to 17.2)
I create Y axes in code behind :
  yAxis = new NumericYAxis();
                yAxis.Title = IdYAxis;
                yAxis.Tag = IdYAxis;
                AxisLabelSettings setaxlab = new AxisLabelSettings();
                switch (PositionYaxis)
                    case ePositionYAxis.IN_LEFT: setaxlab.Location = AxisLabelsLocation.InsideLeft; break;
                    case ePositionYAxis.OUT_LEFT: setaxlab.Location = AxisLabelsLocation.OutsideLeft; break;
                    case ePositionYAxis.IN_RIGHT: setaxlab.Location = AxisLabelsLocation.InsideRight; break;
                    case ePositionYAxis.OUT_RIGHT: setaxlab.Location = AxisLabelsLocation.OutsideRight; break;
                setaxlab.Foreground = new SolidColorBrush((Color)ColorConverter.ConvertFromString(couleurAxis));
                yAxis.LabelSettings = setaxlab;
                yAxis.Foreground = new SolidColorBrush((Color)ColorConverter.ConvertFromString(couleurAxis));
               TitleSettings titleset =(TitleSettings) YNumericAxisbase.TitleSettings.Clone();
                titleset.Foreground = new SolidColorBrush((Color)ColorConverter.ConvertFromString(couleurAxis));
                titleset.Angle = 270;
                yAxis.TitleSettings = titleset;
                yAxis.MajorStrokeDashArray = new DoubleCollection(new double[] { 1, 7 });
                yAxis.MajorStroke = new SolidColorBrush((Color)ColorConverter.ConvertFromString(couleurAxis));
                yAxis.MinimumValue = Miny;
                yAxis.MaximumValue = MaxY;
                _owner.Axes.Add(yAxis);
But I now have multiple Binding errors  when I run the software :
System.Windows.Data Error: 40 : BindingExpression path error: 'Effect' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=Effect; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'Effect' (type 'Effect')
System.Windows.Data Error: 40 : BindingExpression path error: 'Foreground' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=Foreground; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'Foreground' (type 'Brush')
System.Windows.Data Error: 40 : BindingExpression path error: 'FontFamily' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=FontFamily; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'FontFamily' (type 'FontFamily')
System.Windows.Data Error: 40 : BindingExpression path error: 'FontSize' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=FontSize; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'FontSize' (type 'Double')
System.Windows.Data Error: 40 : BindingExpression path error: 'FontStretch' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=FontStretch; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'FontStretch' (type 'FontStretch')
System.Windows.Data Error: 40 : BindingExpression path error: 'FontStyle' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=FontStyle; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'FontStyle' (type 'FontStyle')
System.Windows.Data Error: 40 : BindingExpression path error: 'FontWeight' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=FontWeight; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'FontWeight' (type 'FontWeight')
System.Windows.Data Error: 40 : BindingExpression path error: 'HorizontalAlignment' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=HorizontalAlignment; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'HorizontalAlignment' (type 'HorizontalAlignment')
System.Windows.Data Error: 40 : BindingExpression path error: 'IsHitTestVisible' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=IsHitTestVisible; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'IsHitTestVisible' (type 'Boolean')
System.Windows.Data Error: 40 : BindingExpression path error: 'OpacityMask' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=OpacityMask; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'OpacityMask' (type 'Brush')
System.Windows.Data Error: 40 : BindingExpression path error: 'Opacity' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=Opacity; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'Opacity' (type 'Double')
System.Windows.Data Error: 40 : BindingExpression path error: 'Margin' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=Margin; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'Padding' (type 'Thickness')
System.Windows.Data Error: 40 : BindingExpression path error: 'VerticalAlignment' property not found on 'object' ''AnalysePatientViewModel' (HashCode=38220454)'. BindingExpression:Path=VerticalAlignment; DataItem='AnalysePatientViewModel' (HashCode=38220454); target element is 'TextBlock' (Name=''); target property is 'VerticalAlignment' (type 'VerticalAlignment')
Those errors are repeated for each Y axe I add in the xamdatachart, I think it has to do with the axis title textblock.
For a reason I don't inderstand the textblock semmes to try to find its values directly on the control Viewmodel ...  I did not have those errors unsing 17.2.
If I create the axes in xaml , I dont have any errors, I tried to compare the objects (xaml created axis vs code created axis) but could not find the cause of this problem.
Thanks in advance
