50
Bug in 18.1.255 - '{DependencyProperty.UnsetValue}' is not a valid value for property 'BorderBrush'.
Local WPF Project with Infragistics 18.1.255 via Nuget.
I get the aforementioned Error in a XamDataGrid
Downgrade to 18.1.176 (via Nuget) solves the error.
I tracked the Error down the visual tree to the following Element:
  1. XamDataGrid
  2. [...]
  3. PART_RecordContentSite
  4. DockPanel
  5. CellContent
  6. ContentItemGrid
  7. CellValuePresenter
  8. CardPanel
  9. PART_EditorSite
  10. XamTextEditor
  11. Border
Stacktrace:
System.Windows.Markup.XamlParseException
  HResult=0x80131501
  Message='{DependencyProperty.UnsetValue}' is not a valid value for property 'BorderBrush'.
  Source=PresentationFramework
  StackTrace:
   at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
   at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlReader templateReader, XamlObjectWriter currentWriter)
   at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlObjectWriter objectWriter)
   at System.Windows.FrameworkTemplate.LoadOptimizedTemplateContent(DependencyObject container, IComponentConnector componentConnector, IStyleConnector styleConnector, List`1 affectedChildren, UncommonField`1 templatedNonFeChildrenField)
   at System.Windows.FrameworkTemplate.LoadContent(DependencyObject container, List`1 affectedChildren)
   at System.Windows.StyleHelper.ApplyTemplateContent(UncommonField`1 dataField, DependencyObject container, FrameworkElementFactory templateRoot, Int32 lastChildIndex, HybridDictionary childIndexFromChildID, FrameworkTemplate frameworkTemplate)
   at System.Windows.FrameworkTemplate.ApplyTemplateContent(UncommonField`1 templateDataField, FrameworkElement container)
   at System.Windows.FrameworkElement.ApplyTemplate()
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at Infragistics.Windows.Controls.CardPanel.MeasureOverride(Size availableSize)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at Infragistics.Windows.DataPresenter.DataItemPresenter.MeasureOverride(Size availableSize)
   at Infragistics.Windows.DataPresenter.CellValuePresenter.MeasureOverride(Size availableSize)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.VerifyCellsInView(Size elementSize)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.ArrangeOverride(Size finalSize)
   at System.Windows.FrameworkElement.ArrangeCore(Rect finalRect)
   at System.Windows.UIElement.Arrange(Rect finalRect)
   at MS.Internal.Helper.ArrangeElementWithSingleChild(UIElement element, Size arrangeSize)
   at System.Windows.Controls.ContentPresenter.ArrangeOverride(Size arrangeSize)
   at Infragistics.Windows.Controls.CardPanel.ArrangeOverride(Size finalSize)
   at System.Windows.Controls.Control.ArrangeOverride(Size arrangeBounds)
   at System.Windows.Controls.DockPanel.ArrangeOverride(Size arrangeSize)
   at System.Windows.Controls.Grid.ArrangeOverride(Size arrangeSize)
   at System.Windows.Controls.Border.ArrangeOverride(Size finalSize)
   at Infragistics.Windows.DataPresenter.RecordPresenter.ArrangeOverride(Size finalSize)
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.ArrangeHelper(UIElement visualChildElement, Dictionary`2 headerRecordMap, Boolean orientationIsVertical, Boolean isReverseLayoutForBottomFixed, Double extentUsedByLastItem, Double clipExtent, Size arrangeSize, Rect& arrangeRect, Double& recordIndent)
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.ArrangeOverride(Size finalSize)
   at System.Windows.Controls.ItemsPresenter.ArrangeOverride(Size arrangeSize)
   at System.Windows.Controls.ScrollContentPresenter.ArrangeOverride(Size arrangeSize)
   at System.Windows.Controls.ScrollViewer.ArrangeOverride(Size arrangeSize)
   at Infragistics.Windows.Controls.IGControlBase.ArrangeOverride(Size finalSize)
   at System.Windows.Controls.Decorator.ArrangeOverride(Size arrangeSize)
   at System.Windows.Documents.AdornerDecorator.ArrangeOverride(Size finalSize)
   at System.Windows.Window.ArrangeOverride(Size arrangeBounds)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Window.ShowHelper(Object booleanBox)
   at System.Windows.Window.ShowDialog()
