35
LoadCustomizations unhandled exception with invalid xml format
I am using 17.2 and have following code,
try
                            string error = null;
                            this.DataGridControl.LoadCustomizations(fs, true, out error, CustomizationType.None);
            catch(Exception ex)
                            //ignore exception caused by loading xml file, like invalid element etc
I have manually changed xml element (<fieldLayouts> to <fieldLayouts1>) in saved xml file created by SaveCustomizations(fs, true) and then loaded with above code. As expected I can see error message as below, and no exception catch from above.
The 'fieldLayouts1' start tag on line 3 position 4 does not match the end tag of 'fieldLayouts'. Line 71, position 5.
Issue is after exit from above code and keep running there is an unhandled exception as below, and I have no way to catch it.
System.Reflection.TargetInvocationException
  HResult=0x80131604
  Message=Exception has been thrown by the target of an invocation.
  Source=mscorlib
  StackTrace:
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
Inner Exception 1:
InvalidOperationException: Invalid root element in LoadCustomizations.
Can anyone tell me although I have returned error message from LoadCustomizations why exception isn't handled internally by XamDataGrid control? Thanks!
