I'm styling the expanderbar as below. I can't get it to show. It could be the theme that it's overriding it but I need to set this in a shared resource file, not on part of the actual XamDataGrid resources. Can someone please suggest how to set this in a resource file? Thanks.
<Style TargetType="{x:Type igControls:ExpanderBar}" >
<Setter Property="Background" Value="Blue"/>
<Setter Property="Margin" Value="1,10,1,1"/>
<Setter Property="BackgroundHover" Value="Green"/>
<Setter Property="Visibility" Value="Visible"/>
</Style>
Cristina.
I was able to resolve this. Thank you for all your help!
Hi Andrew,
I am not applying a theme to XamDataGrid. I am to other controls but not XamDataGrid. I have all shared styles in a shared dictionary. Can you please show me an example of "merge that with the XamDataGrid.Resources section"?
Thank you.
Hello Cristina,
If you are currently applying a theme to the XamDataGrid, any resources that you place outside of the XamDataGrid.Resources will be overwritten by that particular theme. As such, I would recommend that you move any resources that you have to a ResourceDictionary and merge that with the XamDataGrid.Resources section - or just add the styles directly to that section.
Every WPF element only takes one local style, and so by applying a "theme" you are applying a set of styles local to the XamDataGrid, but these can be overwritten by the styles in the XamDataGrid.Resources section.
