1160
How do I populate a ComboEditorTool combobox programmatically?
I tried the following and get "Object reference not set to an instance of an object." when I try to add the first item (a string) to the combobox (there is a value in s at the time).  What's the correct way to do this:
XAML snippet:
 <igRibbon:RibbonTabItem Header="Skins">
<igRibbon:RibbonGroup Id="skins" Caption="Skins" >
<igRibbon:ComboEditorTool
Id="cetSkins"
x:Name="cetSkins"
DropDownResizeMode="VerticalOnly"
IsEditable="False"
SelectedItemChanged="cetSkins_SelectedItemChanged"/>
</igRibbon:RibbonGroup>
 Code:
 public Window1()
InitializeComponent();
string[ f = Directory.GetFiles("skins", "skin*.xaml");
foreach (string s in f)
this.cetSkins.ComboBox.Items.Add(s);
I've also tried putting my code in as separate Window_Loaded event but that fails the same way.
Thanks!
 Glenn L
