35
CellStyleCelector with particular behavior + Blinking
I'm trying your XamlGrid to substitute a Telerik one that goes under pressure with a lot of data and high frequency update. With no style it performs really well but now I need to test your under pressure with style selections.
The first thing I need to verify is that all the features I've under your competitor works fine here.
In my DTO I've got a field IdStatus that based on this value it colors the whole row of a color taken from DB.
Now consider the following Converter
 public class StatusRowColorStyleSelectorBase : IValueConverter
        protected Dictionary<int, SolidColorBrush> StatuStyles;
        public StatusRowColorStyleSelectorBase()
            StatuStyles = new Dictionary<int, SolidColorBrush>
                {(int) StatusTypeEnum.Inserted, CreateStyle("Transparent")},
                {(int) StatusTypeEnum.Cancelled, CreateStyle("#ff4500")},
                {(int) StatusTypeEnum.Validated, CreateStyle("#00bfff")},
                {(int) StatusTypeEnum.Exported, CreateStyle("#90ee90")}
        private static SolidColorBrush CreateStyle(string color)
            var convertFromString = ColorConverter.ConvertFromString(color);
            if (convertFromString is Color c)
                return new SolidColorBrush(c);
            return new SolidColorBrush(Colors.Transparent);
        public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
            if (value is IStatus status)
                return StatuStyles[status.IdStatus];
            return value;
        public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
            throw new NotImplementedException();
And I've seen a sample where you do
<igDP:XamDataGrid Name="xamDataGrid1" BindToSampleData="True">
            <igDP:XamDataGrid.Resources>
                <Style TargetType="{x:Type igDP:DataRecordCellArea}">
                    <Style.Triggers>
                        <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path= Record.Cells[1].Value}" Value="Sales" >
                            <Setter Property="Background" Value="Orange" />
                        </DataTrigger>
                    </Style.Triggers>
                </Style>
            </igDP:XamDataGrid.Resources>
         </igDP:XamDataGrid>
In this code you check on Cell[1], what if the user reorders the column?
It's possible to pass to the converter the whole DataItem?
