Hello there,
I try to use a TimeSpan object on my XamDateTimeEditor-Control, in my final version I need it in a XamTreeGrid or XamDataGrid. Generally binding to a TimeSpan object is possible and I can edit it via numpad but as soon I want to use the Spin Bottons the control “breaks”.
I created a small sample-project.
BR
Andreas
PS: the max. file size of 1mb is quite low
20171218_XamDateTimeEditorSampleProject.zip
Hello Michael,
Thank you for the update, I'm looking forward to the solution.
Hello Andreas,
I have created a support case for you with an ID of CAS-189629-B0D6N4. The matter has been determined to be a development issue and has been logged in our tracking system with ID: 247369.
I will leave this case open and update you with any new information. You can view the status of the development issue connected to this case by going to the “Account” tab on our website, selecting "My Support Activity" and then this support case will be listed there. Then, you may select the "Development Issues" tab to view details of this development issue.
Thank you for posting on our forums!
I am able to reproduce the exceptions and "breaking" behavior where the value disappears using your sample when using the Spin Buttons.
I will need a little more time to investigate this and I will have more information or questions for you by Thursday.
Sincerely,Michael H.Software DeveloperInfragistics, Inc.www.infragistics.com/support
