40
Change the LabelTemplate on an Infragistics XamDoughnutChart
I have an Infragistics WPF XamDoughnutChart which displays data binded from an ObservableCollection called Data and shows Data.Value and Data.Label on its chart labels.
<Grid>
    <ig:XamDoughnutChart x:Name="MyDonut"
                         CenterData="{Binding TotalItemCount}">
        <ig:XamDoughnutChart.Series>
            <ig:RingSeries ItemsSource="{Binding Data}"
                           ValueMemberPath="Value"
                           LabelMemberPath="Label">
            </ig:RingSeries>
        </ig:XamDoughnutChart.Series>
    </ig:XamDoughnutChart>
</Grid>
I am trying to change the LabelTemplate but nothing I try works:
<Window.Resources>
    <DataTemplate x:Key="MyLabelTemplate">
        <Label Foreground="Blue" Content="test"/>                 <-- **This shows 'test' in blue
        <Label Foreground="Blue" Content="{Binding}"/>            <-- Does nothing
        <Label Foreground="Blue" Content="{Binding Path=Label}"/> <-- Does nothing
        <Label Foreground="Blue" Content="{Binding Path=Value}"/> <-- Does nothing
    </DataTemplate>
</Window.Resources>
<Grid>
                         CenterData="{Binding TotalCount}">
                           LabelTemplate="{StaticResource MyLabelTemplate}">  <-- **Add a LabelTemplate**
            </ig:RingSeries>
</Grid>
How can I actually change this labels template?
  • 34510
    Verified Answer
    Hi Jimmy,
    The DataContext for your template is an Infragistics object which exposes an Item property you can use to get your datasource item.  So your binding should look like this: {Binding Path=Item.Label}.
